photo's by Laura Stretz
Remove these ads by
Signing UpStep 1Parts list
Wanted to use an altoids tin, but my phone jacks wouldn't fit and i didn't want to switch to minis. So I found this Project Enclosure (3x2x1") at my local radioshack for $2.30
absolutely had to use the most obnoxious chickenhead knob I had. Got from mouser for $2.40
Components:
1 x .05uf film cap
1 x 10k resistor
1 x 1k resistor
1 x 10k 12mm log pot
wire (I used 22AWG solid core because it's what I had, use what you want here)
total cost per mouser: $2.47
Jacks, Cable, & Plugs:
I had a cheapo instrument cable that had a short in it somewhere, so I cu the ends off and used the cable for this project. I rang out each piece to make sure it didn't contain the short.
Jacks are Radioshack 1/4" Mono Panel-Mount Audio Jack (2-Pack) $3.99
Plugs are Radioshack Standard Phone Plug (2-pack) $3.99
Grand total cost: $15.10 (The jacks were a little cheaper in the store and everything is cheaper if you get it somewhere that's not RadioShack. It's concievable to get this down to about half the cost without too much effort)
if i run one output to my amp and the second back through
into the second input would i get the same thing?
or would i need a some kind of resistance and not just the patch cord?
thanks
I'd just crack open the patch cable in the middle and put in a pot with one pin on the signal wire and another on the ground/shield and the last pin not connected to anything. If the pedal has two inputs, it should have it's own mixer built in so you're all set. Try the patch without modification first to make sure the signal gets fed back in before you go cutting up patch cables though. ;)
Let us know how it works out. If it works like we're thinking it will, I may have to get a new pedal. :)
thanks again for the response, you were a lot of help!!!! do you have a site with your own stuff?
Looking forward to seeing your testing.
