3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Apocatastasis (feedback return for cheap digital delays)
Most expensive analog delay pedals have a feedback knob that lets you drive the output of the delay effect back into the input. My Ibanez DL5 Digital Delay did not have this feature, so I decided to make one and make it cheap. :-)
photo's by Laura Stretz
Step 1Parts list
Parts list
Chassis and knob:
Wanted to use an altoids tin, but my phone jacks wouldn't fit and i didn't want to switch to minis. So I found this Project Enclosure (3x2x1") at my local radioshack for $2.30
absolutely had to use the most obnoxious chickenhead knob I had. Got from mouser for $2.40
Components:
1 x .05uf film cap
1 x 10k resistor
1 x 1k resistor
1 x 10k 12mm log pot
wire (I used 22AWG solid core because it's what I had, use what you want here)
total cost per mouser: $2.47
Jacks, Cable, & Plugs:
I had a cheapo instrument cable that had a short in it somewhere, so I cu the ends off and used the cable for this project. I rang out each piece to make sure it didn't contain the short.
Jacks are Radioshack 1/4" Mono Panel-Mount Audio Jack (2-Pack) $3.99
Plugs are Radioshack Standard Phone Plug (2-pack) $3.99
Grand total cost: $15.10 (The jacks were a little cheaper in the store and everything is cheaper if you get it somewhere that's not RadioShack. It's concievable to get this down to about half the cost without too much effort)
22 comments
Jul 12, 2010. 12:18 AMrathergood says:
Thank you for your quick reply. As far as ground goes for a pedal like this, how do I connect them all together? The only circuits that I have ever made I have used a 9V battery, so it was simple to understand where all of the grounds went to. For this, my intuition kinda goes out the window. Thank you for your patience.
Jul 5, 2010. 12:50 AMrathergood says:
I'm a bit new to electronics so I have a few questions. On all the jacks (or jacks/plugs in your case) on your schematic you only have one wire going to it, which I am confused about. Is there some invisible standard that I don't know about, like all the grounds are hooked up to a specific place. I tried figuring it out with the picture, but it isn't quite clear enough to see every connection. Also, just out of curiosity, at a components/conceptual level how/why does this circuit create feedback? Thank you, any help and/or clarification is appreciated
Jun 16, 2010. 10:58 AMA good name says:
This will sound really lame, but what is feedback exactly? I've heard Tom Morello uses it for quite a few songs, but I'm sort of vague on what it is.
Nov 16, 2009. 5:12 PMcoliusuriah says:
i have a LINE 6 ECHO PARK delay with stereo in and out
if i run one output to my amp and the second back through
into the second input would i get the same thing?
or would i need a some kind of resistance and not just the patch cord?
thanks
Nov 17, 2009. 9:35 AMcoliusuriah says:
thanks alot for the information! ill try it both ways. hopefully ill have enough time this week.. i will post my results and a link to a video when it happens.
thanks again for the response, you were a lot of help!!!! do you have a site with your own stuff?
Jun 19, 2009. 7:25 AMLeoneVuetivavalagi says:
Hi I was just wondering if it has to be a film capacitor or whether I could use a ceramic disc?
Mar 17, 2009. 6:21 PMmikebruse says:
I'm also new to electronics. After wiring everything together with what I'm pretty sure are the right parts, the pot basically acts as just a volume switch, any ideas?
Mar 18, 2009. 6:16 PMmikebruse says:
I'm not really sure what is going on; I have it hooked up to a fuzz pedal which now only slightly extends the note length. I have the pot turned all the way up too.
Jan 14, 2009. 4:46 PMefilho says:
Did anyone tried it on a DIST/OD? Any sound clips? Cheers!
Dec 21, 2008. 9:38 PMacousmatic says:
please be patient with me...long time player but brand new to electronics....it worked really well except the repeats all sounded like they were up two octaves, not natural like your audio examples(quite ear piercing). Could it be the capacitor? the closest i could find to a 0.05 film cap was '0.047uF/47nF Greencap Metallised Polyester Capacitor ', '0.047uF 50V Blue Chip Monolithic Capacitor ' and a '0.047uF 50 Volt Ceramic Capacitor'. (i used the first option). your help is very much appreciated. great project!
Dec 21, 2008. 2:03 AMacousmatic says:
hey! just wired it all together... can you quickly explain the reverse wiring (tip) on the mono jack, not sure i understand. do you mean to say that the 'earth' becomes the 'signal'? but only on one of them? thanks! cant wait to plug it in!
Aug 28, 2008. 9:58 AMthedbc says:
sweet, thanks. I am going to build this into the box with a diy digital delay I just got in the mail.
Aug 27, 2008. 7:49 PMskincage says:
This is a great workaround for pedals that don't come with the ability to self-oscillate. Having a breakout box means you can use it on any effect rather than having a permanent mod in a pedal case that could eventually cause a problem. Thank you for sharing this.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:pstretz
