Introduction: Apple Butter Pumpkin Pie
I present to you my Pretty Pretty Apple Butter Pumpkin Pie :) I have
never used sprinkles before and I got so exited when I started placing the stars on the whipped cream, that i could not stop myself from completely covering the cake with sprinkles..ha ha This is an easy pie but a little time consuming and the outcome is definitely worth all the effort. Hope you like it :)
Step 1: Ingredients and Steps to Prepare Apple Butter
Ingredients required :
- Apples - 3 medium any type
- Brown Sugar - 1/2 cup
- Water - 1/4 cup
- Ground cinnamon - 1/4 tsp heaped
- Ground Nutmeg - 1/8 tsp
- Ground cloves - 1/8 tsp
- Lemon Juice - 1 tsp
Steps required :
- Peel and chop the apples.
- Place all the ingredients in a pressure cooker, mix, put the lid and let it cook for 10 minutes(4 vissels).
- Once the steam evaporates from the cooker, open the lid. The apples were already in the form of paste, so i did not need to mash it. Very little liquid was left in the cooker, so I cooked it for another 5 minutes to thicken it.
- Let it cool, store it in a airtight container and refrigerate it till required.
Step 2: Steps to Prepare Pumpkin Puree
- Wash a small Sugar Pumpkin or Pie Pumpkin very well
- Cut the top which holds the stem of the Pumpkin and cut the pumpkin into half
- Remove the seeds and strings well (Do not throw the seeds as the seeds can be used so many ways)
- In a pressure cooker pour 1 inch water, place the pumpkin pieces, put the lid and let it cook for 10 minutes (1 vissel)
- Once the steam settles, open the cooker lid, remove the skin of the pumpkin which comes off easily, mix well with a spoon and place in refrigerator till needed.
Step 3: Ingredients and Steps to Prepare Pie Crust
Ingredients required (Quantity below adjusted for only one pie crust):
- All purpose Flour - 1 cup
- Powdered Sugar - 1/3 cup
- Salt - 1/8 tsp
- Butter - 1/2 cup, very cold cut in small chunks
- Ice Water - 2 tbsp
Steps required :
- Cut the cold butter into small cubes and keep aside
- In a large bowl + All purpose flour + powdered sugar + salt - Mix well
- Add butter to above mixture and with the help of finger tips mix the butter into the flour till the butter becomes pea sized
- I moved the mixture to a flat based bowl so that i could mix the mixture well
- Add Ice cold water little by little till you are able to gather the mixture into a ball.
- In the photo I have divided the dove into 2 because I made extra. The ingredient quantity mentioned above is for only one pie crust which is enough for this pie.
- Wrap the Pie dove in plastic wrap and place in fridge for 30 minutes
- After 30 minutes roll out the dove to 1/4 inch width and carefully place it onto a pie pan or tart pan
- With a fork make dots on the pie crust so it does not fluff once baked
- Place in fridge till needed
Step 4: Ingredients and Steps to Prepare Apple Butter Pumpkin Pie
- Pumpkin Puree - 1 cup
- Condensed Milk - 1 cup
- Apple Butter - 1 cup I 9" pie crust, fitted in a 9" pie plate
- Salt - 1/4 tsp
- Eggs - 2
- Ground Nutmeg - 1/4 tsp
- Ground Cinnamon - 1 tsp
- Ground Ginger - 1/2 tsp
- Ground Cloves - 1/4 tsp
Steps required :
- Preheat oven to 425 degrees
- In a large bowl, combine together all remaining ingredients. Pour in the pie crust and bake it for 15 minutes
- Reduce the heat to 350 and continue to bake for another 30 to 40 minutes or until no longer jiggly in the center
- Allow to cool at room temperature for about an hour, then pop it in the fridge to cool completely
Step 5: Presenting the Pie
- In a bowl + cold heavy cream (1/2 cup) and whip till foamy + powdered sugar ( 1tbsp) and whip till stiff peaks forms
- Pour the whipped cream into a zip lock bag fitted with flower nozzle
- Decorate as desired and have fun with sprinkles :)
Pumpkin Challenge
