This MacBook had a Superdrive problem where the drive lock was up preventing disk insertion, also the drive would frequently go through eject cycle even though there was no disk in the drive.
I was hoping to avoid having to purchase a new drive. This is NOT REPLACEMENT BUT REPAIR!!! Yes it worked and was 100% effective and brought it back from the dead... Zombie MAC...
I will not cover part of the dis-assembly here as that has been done to death on the internet. You will need to remove the hard drive so follow that procedure.
This model is the Mid 2007 13 inch MacBook.
You will need a number 0 and a number 00 Phillips screwdrivers along with an X-Acto type knife.
Remove these ads by
Signing UpStep 1Remove the drive
The first is in the hard drive bay and the second is along the upper edge of the drive hidden by some wires.
The drive also has a hidden locking mechanism that will need to be disengaged in order to lift it out.
All of these screws are a number 0 Phillips but the lengths are different, be sure to note which screw came from which location.
Once all of the screws are removed, you will need to disconnect the sensors and wires, Use extreme care since the wires are tiny and limited in length.
comments
Add Comment
Add Comment
