Introduction: Apple Noodles
A simple recipe to make noodles with apples and corn flour. Here, I have used the apple paste to make the dough for the noodles. You can use corn flour or rice flour, both taste delicious.
Step 1: Ingredients Required
- 2 numbers of fresh apples
- 2 to 3 cups of corn flour
- Half coconut
- Sugar to taste
- Salt to taste
- Food color
- A teaspoon of cooking oil
Step 2: Equipment
- An Idli steamer works best for this. You can use any steamer available or use a wide mouthed vessel
- Noodle press. I have used a mold with medium holes
Step 3: Make Apple Paste
- Peel apples
- Cut the peeled apples in to pieces and clean the core
- Place the pieces in a mixer / blender
- Add a pinch of food coloring
- Add salt to taste
- Make paste and store it in a bowl (Do not add any water)
Step 4: Make Dough
- Now add the corn flour in small quantities to the apple paste and mix well. Do not add any water as the paste has lots of apple juice
- Make the dough to the consistency of potting clay
Step 5: Temper the Dough
This step is very important, otherwise you can not press the dough in to noodles
- Heat a teaspoon of any cooking oil in a pan
- Add the dough and lightly temper it
Step 6: Make Noodles and Steam-cook
- Boil water in a steamer. Here I have used an Idli cooker. You can use any wide mouthed vessel with a proper lid for this
- Place the Idli pan and spread a clean cotton cloth over it. If you are using a vessel, then tie a cotton cloth on top loosely
- Place the tempered dough in the Noodle press
- Press noodles on the idli pan
- Cover with the lid and cook for about 10 minutes
Step 7: Remove Noodles From Steam
- After about ten minutes, check to see the noodles are properly cooked. If not, steam for a few more minutes
- remove from the steamer and separate the noodles from the Idli pan
- Brake the hot noodles loose
Step 8: Grate Coconut
- The noodles are served with grated coconut, which will add an aroma and taste to the noodles
- Grate about half a coconut using a grater
Step 9: Garnish and Serve
- Spread the grated coconut over the steamed noodles
- Sprinkle sugar over the hot noodles to your taste
- Serve hot.
Uppermost Chef: Apples Challenge
