AppleScript for Creating a Text File in the Current Finder Directory
1,352
9
Posted
Introduction: AppleScript for Creating a Text File in the Current Finder Directory
You know the situation: in OSX you simply want to create a quick textfile in your current Finder folder (dare I mention the Desktop?). AppleScript comes to the rescue!
Step 1: Add the AppleScript Icon to the OSX Menu Bar
Inside the AppleScript editor (in your OSX Applications - Utilities) go to Preferences - General and check
[x] Show Script menu in menu bar
Step 2: Add This Script to Your User Scripts
-- H.Zimmerman, AppleScript.
-- Create text file in current Finder folder with a dialog.
tell application "Finder"
    try
        display dialog "name of doc please (without the .txt thing)" default answer ""
        set fileName to the text returned of result
        if length of fileName = 0 then
            return 0
        end if
        set fileExt to ".txt"
        set thisFolder to the target of the front window as alias
        set newFile to fileName & fileExt
        make new file at thisFolder with properties {name:newFile, file type:"TEXT", creator type:"ttxt"}
    on error errMsg
        display dialog (errMsg)
    end try
end tell
Step 3: Make a Text File
In the appropriate Finder folder, simply select the menu item you just added, type a name and your file is there. Double clicking it will open the familiar Text Edit.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
