Application of MCP-23008 Using Relay Interface (I2C):
Published
Introduction: Application of MCP-23008 Using Relay Interface (I2C):
About: We are a group of makers. We work in IoT, IOS app, android app, embedded design, sensor design, raspberry pi, arduino, beaglebone, particle electron, particle photon, Bluetooth.
Hello
Good Greetings..!!
I (Somanshu Choudhary) on the behalf of Dcube tech ventures going to control Relays via I2C protocol using Arduino nano and MCP23008.
Step 1: Overview
  • The MCP23X08 device provides 8-bit, general purpose, parallel I/O expansion for I2C bus or SPI applications.
  • The MCP23X08 consists of multiple 8-bit configuration registers for input, output and polarity selection. The system master can enable the I/Os as either inputs or outputs by writing the I/O configuration bits. The data for each input or output is kept in the corresponding Input or Output register. The polarity of the Input Port register can be inverted with the Polarity Inversion register. All registers can be read by the system master.
  • DATASHEET LINK : http://ww1.microchip.com/downloads/en/DeviceDoc/21...
Step 2: What You Need / Links
Step 3: Circuit Diagram
Step 4: Programming - I
  • In this code, I use Function Programming Paradigm
  • I used different tabs for functions definition and function calling
CODE UNDER TAB q :
// Simple function calling code
#include
void setup()
// I2C address of the MCP23008
#define MCP_ADDR 0x20
// Join I2C Bus as master
Wire.begin();
// Start serial communication and set baud rate
Serial.begin(9600);
// Begin transmission with given device on I2C bus
Wire.beginTransmission(MCP_ADDR);
// Select IODIR – I/O DIRECTION REGISTER register
Wire.write(0x00);
// Select required operation (output)
Wire.write(0x00);
// Select CONFIGURATION register
Wire.write(0x05);
Wire.write(0x0E);
// end transmission
Wire.endTransmission();
void loop()
a1_on();
delay(1000);
a1_off();
delay(1000);
a2_on();
delay(1000);
a2_off();
delay(1000);
a3_on();
delay(1000);
a3_off();
delay(1000);
a4_on();
delay(1000);
a4_off();
delay(1000);
a5_on();
delay(1000);
a5_off();
delay(1000);
a6_on();
delay(1000);
a6_off();
delay(1000);
a7_on();
delay(1000);
a7_off();
delay(1000);
a8_on();
delay(1000);
a8_off();
CODE UNDER TAB q1 :
// This code is to on and off relay 1 on board
void a1_on()
Wire.write(0x09);
Wire.write(0x01);
delay(1800);
Wire.requestFrom(MCP_ADDR, 1 );
int GPIO = Wire.read();
// Output to the screen
Serial.print("GPIO value :");
Serial.println(GPIO,BIN);
void a1_off()
Wire.write(0x09);
Wire.write(0x00);
delay(1800);
CODE UNDER TAB q2 :
// This code is to on and off relay 2 on board
void a2_on()
Wire.write(0x09);
Wire.write(0x02);
delay(1800);
void a2_off()
Wire.write(0x09);
Wire.write(0x00);
delay(1800);
CODE UNDER TAB q3:
// This code is to on and off relay 3 on board
void a3_on()
Wire.write(0x09);
Wire.write(0x04);
delay(1800);
void a3_off()
Wire.write(0x09);
Wire.write(0x00);
delay(1800);
Step 5: Programming - II
CODE UNDER TAB q4:
// This code is to on and off relay 4 on board
void a4_on()
Wire.write(0x09);
Wire.write(0x08);
delay(1800);
void a4_off()
Wire.write(0x09);
Wire.write(0x00);
delay(1800);
CODE UNDER TAB q5:
// This code is to on and off relay 5 on board
void a5_on()
Wire.write(0x09);
Wire.write(0x10);
delay(1800);
void a5_off()
Wire.write(0x09);
Wire.write(0x00);
delay(1800);
CODE UNDER TAB q6:
// This code is to on and off relay 6 on board
void a6_on()
Wire.write(0x09);
Wire.write(0x20);
delay(1800);
void a6_off()
Wire.write(0x09);
Wire.write(0x00);
delay(1800);
CODE UNDER TAB q7:
// This code is to on and off relay 7 on board
void a7_on()
Wire.write(0x09);
Wire.write(0x40);
delay(1800);
void a7_off()
Wire.write(0x09);
Wire.write(0x00);
delay(1800);
CODE UNDER TAB q8:
// This code is to on and off relay 8 on board
void a8_on()
Wire.write(0x09);
Wire.write(0x80);
delay(1800);
void a8_off()
Wire.write(0x09);
Wire.write(0x00);
delay(1800);
Step 6: Video
For further quires Feel free to visit our site:
www.dcubetechnologies.com
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
