Introduction: Application Thermal Waterproofing System
Picture of Application Thermal Waterproofing System
Prepare the substrate properly (remove all loose material, oils, dust and protruding objects). Clear the surface thoroughly and level as much as possible.
Step 1: Thermal Waterproofing System
Picture of Thermal Waterproofing System
Step 2:
Picture of
Using a notched trowel, apply to the surface the appropriate mortar adhesive, ULTRACOLL THERMO, at approximate thickness of 10mm.
Step 3:
Picture of
Step 4:
Picture of
Coat the surface of the thermal insulation panels with the Quartz base Acrylic Primer DS-255
(two layers crosswise).
Step 5:
Picture of
Continuing, after 24 hours apply to the surface (in thicknesses from 4-10cm) the fiber fortified cement screed, D-6 reinforced by using the fiberglass mesh, DS- 090. Alternately, use traditional screed containing gravel, sand and cement at a ratio of 1:3:1, reinforced with steel/metallic mesh.
Step 6:
Picture of
Soak the entire surface with water, 3-4 times within the next 24 hours.
Step 7:
Picture of
Begin coating the surface, approximately 1m wide each time, with the cementitious waterproofing mortar HYDROSTOP ROOF.
Step 8:
Picture of
Apply and incase the fiberglass mesh on the coated surface, 1m wide at the time and continue with the next strip making sure to overlap each piece about 10cm at every junction. Continue on the entire surface until completion of the first coat of HYDROSTOP ROOF.
Step 9:
Picture of
My thermal waterproofing system im my place is ready !!
matthewtweedie (author)2016-08-22
good project
Davidecristiana (author)2016-04-24
like the work
Fionaussie (author)2015-10-05
Thx for sharing. There is a missing instruction after using the notched trowel to apply mortar (this instruction is repeated twice). I'm going to use your instructable on my garage roof to create an additional outdoor space!
tomatoskins (author)2015-10-02
So cool! Thanks for sharing and welcome to the community!
About This Instructable
4,493views
63favorites
License:
More by adliamis:Application thermal waterproofing system
Add instructable to:
