Step 5Removal and storage
Any spirit gum residue left on your skin can be removed by scrubbing with soap and water. Or if you plan to use the ears quite often, you can use spirit gum remover to more easily remove the residue from your skin. However, if you only intend to use the elf ears infrequently, soap and water should be fine.
Don't use spirit gum remover on the elf ears. While it will remove the dried glue from your ears, it will also take off the RMG make-up. Instead, wait until after you have worn the ears about 10 times or so. Before you put them on again, you will notice a nice build-up of spirit gum on your prosthetic. Gently take your fingernail and scratch lightly to remove it. You can also gently stretch the latex. Since spirit gum doesn't stretch when it has dried, it will flake up, making it easier to remove as well.
When you are not wearing your elf ears, keep them in a small plastic bag, such as a ziploc bag. Doing this will protect the latex and help maintain the coloring. A plastic bag will help keep dirt and dust off the ears which will alter the coloring with a grayish tint. I wear mine twice a week in the rain and sun at Renaissance Festivals, but I usually only have to touch mine up every 4-6 months, and I guarantee that I wear mine through much harsher conditions than most.
If you ever have any questions about this tutorial, please feel free to contact me. Thanks!
comment
Add Comment
Add Comment
