Working for that big corporation is going to pay off on April 1st!!!
Remove these ads by
Signing UpStep 1What you will need
We will need the letters that spell APRIL FOOLS
Letter opener
A carefully chosen victim
Plan of attack
Any number of accomplices you deem necessary
unless u have another keyboard -.-'
There are two backfires:
1. If the keyboard is completely unsculpted (look at the keyboard end-on, and the keytops should make a flat surface, not a dished one), then people like myself are probably going to take half a day to notice.--Best comparison, swap the [Esc] key with the [Z] key. On a laptop these would probably blend in without being noticed, but on a desk top keyboard, the different angles of the keytops will stick out like a sore thumb.
2. If the keyboard is sculpted (end-on is dish shaped--the [Esc] and [Z} swap is visually obvious), then when you re-arrange the keys the tops won't align and a touch-typist will pick this up without having looked at the keyboard either.
If your keyboard has passed the above tests, and also happens to be hardware macro-programmable, you can also map your new keys to give the new letters--that would really flip out a touch-typist!
I would suggest using spares for your prank, so that "normal" ones can be replaced quickly, and you can serve your penance of swapping all the keytops back during your lunch break.
It reminds of the rumor that when Georgie W. Bush jnr got elected all the staff ran around the White House removing all the [W] keys from all the computers!
On some keyboards, you can just stick a car key under one side and the top will literally "pop" across the room.
On others, you have to very carefully lift from all four sides of the keys very evenly else the actuator could snap--and keyboard plastic doesn't take kindly to super-glue.
I did that to my friend except not in random order... I put everything backwars so the Q key would be in the P spot and so an so forth.... :D it was funny at the time...
