Step 6Add in aquarium components and decor
An internal power filter, in a corner of the tank is an unobtrusive, yet highly functional way to provide filtration. Likewise, a standard submersible heater will be needed if you're keeping fish that require a temperature other than that of standing water in room temperature. Route the cables down a corner of the tank, through the bottom shelf and to the power strip. Zip tie in place as needed. Usually, it is highly advised not to power these devices until they are under water, so don't plug them in until you've added water.
I used a suction cup, glass tube thermometer mounted diagonally inside the aquarium so that it would be readable while I sat beside the table.
I used colored, flattened glass marbles as substrate in a very thin layer. Any translucent substrate would work.
As there is not a top directly over the aquarium in my configuration, and I plan to add a species known to jump, I have not filled to the very top, but instead I'm leaving 3-4" of "wall" at the top of the tank. Research your desired species or consider an acrylic or glass inset for the top of the tank. Another option would be to configure your shelf height / post length so that the glass table top would be placed almost directly over aquarium. Leave some space for airflow though!
Add Comment
