Aquarium Gravel Cleaner
6,053
15
Published
Introduction: Aquarium Gravel Cleaner
I was looking for a cheap way to clean the gravel in my fish tank. I wanted something inexpensive and also something fun to make!
Things you will need:
-   1 1/2" PVC Extension Tube (Treaded one side)
-   1 1/2" PVC Tubular tightener thing (Sorry don't know the name for it)
-   Tubing (Which ever size you prefer)
-  Ocean Spray Cranberry Juice Lid
-   Drill+Bit (of desired thickness for tubing)
(Something to make a hole in Lid)
There are pictures for my bad job at explaining ;)
Step 1: Things Used
Things Used:
Step 2: Drilling the Lid
I used an Ocean Spray Cranberry Juice lid and it fit perfectly.
1) Drill the lid to the appropriate size of the diameter of your tubing.
For best results, use a small drill and work your way up.
Do not make the hole exactly the size of your tube or it will be loose.
2) Also, I had to trim away half of the lid in order for it to screw on to the tube.
3) Pop the lid inside the other piece.
Step 3: Tubing
Insert the tubing into the hole you just made. I have found that its best if you only insert the tube a little bit. The picture shows you.
ALMOST DONE!!
Step 4: Final Step
The final step is to screw on the tubing, lid, screw Tubular tightener to the extension tube.
Step 5: Final Product
Now you have a Gravel Cleaner that you made yourself with things laying around the basement, or off of a low budget. Have fun and tell me how you like it please.
Also I use it to fill up water for the tank as shown in the video.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Stick It! Contest
      Stick It! Contest
    3 Comments
    what a great idea but looks like a lot of work i suggest a turkey baster
    a clean way of getting the sifen started is a peace of string and a rubber washer that firs in the pipe pull the string thru the pipe with the rubber seal and it pulls the water thru
    my father and i used to use a empy drinks bottls and garden hose
