Arc Reactor Model Powered by Solar Energy
5,972
51
8
Posted in CostumesProps-and-accessories
Introduction: Arc Reactor Model Powered by Solar Energy
About: Hey ! I'm Edward , and u can call me ed . I'm interested in creat something really awee . And I LIKE movies . Also , I love music , it's part of me. U can follow me Plz... and I will follow u back .
These are steps of how to make a model of Arc Reactor powered by solar energy.
这些是如何制作一个由太阳能供电的方舟反应堆模型的步骤。
Step 1: Preparation 准备
Materials that we needs : copper wire , electric iron , pinchers , gloves , giue , LEDs , Acrylic glass , sand paper , and solar cells
需要的材料:铜导线、电烙铁、钳子、手套、胶水、LED灯、亚克力板、砂纸和太阳能电池板
Scour off the membrane for protection on the Acrylic glass .
洗去亚克力面板上用于保护的膜
Step 2: Burnish
Use the sand paper to burnish the clean Acrylic glass to make it looks better .
用砂纸去打磨已经清洗过的亚克力面板从而使它看上去更好
Step 3: Stick Them Togther
Stick the small pieces of Acrylic glass on the circular Acrylic glass.
把小片的亚克力面板粘到圆环状的亚克力面板上。
Step 4: Stick Them Togeter Again ! !
Stick the linear Acrylic glass on the small transparent circular Acrylic glass , one by one .
将线状的亚克力面板粘到透明的小块圆形亚克力面板上,一个接一个。
Step 5: The Energy Ring
Put the iron ring inside the circular Acrylic glass .
将铁环放置到圆环状的亚克力面板里。
Stick them togeter using the glue .
用胶水将它们固定到一起。
Step 6: The Border
Folding the small piece of Acrylic glass into a right angle . (At HIGH temperature)
将小块的亚克力面板折叠形成一个直角。(在较高的温度下进行)
Place these right angles on the border of the big circular Acrylic glass.
将这些小的直角放置到大的圆环状的亚克力面板上。
Step 7: The Main Part
Stick the energy ring on the circular Acrylic glass.
把能量环粘到圆环状的亚克力面板上。
Step 8: The Bottom
Use the electric iron to make two holes at the bottom .
用电烙铁在尾部打出两个小洞。
Pass the copper wire through these two holes .
将童导线传过这两个小洞。
Step 9: Lighting Units
place the LEDs into the holes on the Acrylic cylinder.
把LED灯放置到亚克力圆柱上的小洞里去。
Use electric iron connect the copper wire with one of the LED light.
用电烙铁将铜导线和LED灯焊接起来。
Step 10: Welding
Use the copper wires to connect each LED light .
用铜导线将LED灯串联起来。
Step 11: Bigger Light Unit
Place the LED lights into the holes of circular Acrylic glass , one by one .
将LED灯放置到圆环状的亚克力面板上的小洞里,一个接一个。
Step 12: Solar Cell
Connect the light units with the solar cells using the copper wires .
用铜导线将太阳能电池板与LED灯连接起来。
Step 13: Recharge
Put the solar cells under the sunshine for a while .
将太阳能电池板放在阳光下一会。
Step 14: Final
Turn on the switch .
打开开关。
The "Arc reactor" start to work ! !
"方舟反应堆“开始工作了!!
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    8 Comments
    what the meaning of Acrylic glass
    am i no longer pay electricity bills if i make it
    Tony Stark will be jealous!
    您好!谢谢您参与到绿色电子挑战赛!
    很荣幸的通知您,您的作品已经入围决赛!接下来评审团们将对每个入围作品进行评选,届时将公布最终获奖名单!
    如果您有任何问题,请给此ID发送私信,谢谢。
    再次祝贺并祝您好运!
    -Instructables Team
