Arcade Stick With Rubber Bands
2,215
35
Posted
Introduction: Arcade Stick With Rubber Bands
  • 2 hard bases (can be a tupperware / lunchbox)
  • 1 threaded rod of 8mm with 2 washers and nut's
  • 4 bolts of 4mm with 3 washers and 2 nuts each
  • Rubber bands (min 4)
  • Wires and something to detect the movement (a metal piece, endstops or distance sensor, whatever you want)
Step 1: Important Notes
The hard base is where you will hold the threaded rod that would work as the arcade stick (top base), and another of the hard base (bottom base) is what will hold the contacts that will detect the movement. This can be anything you have at hand, in our caseusing a small tupperware / lunchbox was the best option
Step 2: Preparing the Top Base
Cut a hole of the area that you want the stick would be able to move, at the center on the top base.
Then drill a hole in each of the corners of the top base, this is where each one of the 4mm bolts are going
Adjust each one of the 4mm bolts in the corner holes, looking up.
Step 3: Assembly
Slightly adjust the threaded rod with a washer and nut from top and below the top base
Hookup a rubber band between one threaded rod, below the top washer and one of the corner bolts.Then go to the opossite side and hookup another, and another till you get the desired tensionin the main rod. If the rubber bands are too large, you can twist them to have more tension
Step 4: Detecting the Movement
To detect the movement of the main rod, anything can be used, like endstops or distance sensorsIn this case, we will use the most basic option, just 2 washers at the side's of the threaded rod
Adding the washers at the bottom base, on the left and right side of the threaded rod anda bunch of copper wire at the end of it, to have a better contact, together with a signal wire
Step 5: Done !
And you just made it ! An arcade stick with rubber bands and a couple of bolts!
If you like the content, be sure to follow us!.
Also, you can checkout our games, apps and other DIY projects
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    3 Comments
    Hi, looks cool. Have you tried to put a bolt through each side of the box and maybe some big washers at the end of the rod. If that would work for contact, to avoid having to use any other type of sensors. Simply having ground on the middle and then 1 wire for each screw. 4/8way hardware store joystick.
    Clever. That is way cheaper than a commercial joystick. And you get the fun of making it yourself.
    Yep, that's the idea ! Glad that you liked it ! Be sure to follow us, we will be posting more content very soon :)
