loading
Step 10: Last strap
Next was the underarm strap and this posed two problems.  The first problem was that I wanted to use a smaller buckle to attach this strap to the main strap and the second was how to make the underarm strap attach to the main strap.
Because the straps had already been cut to the same width and attached to the quiver the underarm strap needed to be narrowed.  The center of the strap was marked for the length it needed to be narrow (about 350mm).  Then parallel lines were marked 9mm to each side of the center line (to suit the size of the buckle to be used).  Curves were then drawn in to avoid making square corners (picture 2 this step).  The strap was then cut out with scissors.  The end of the strap was pointed and holes were punched at 10mm intervals to allow the buckle prong to go through.
To enable the underarm strap to be connected to the main strap a sort of mini strap was made and attached to the main strap perpendicular to the main strap.  this little strap was 90mm long before the buckle was attached.  Picture 5 (this step) shows the use of a 12mm carpenters chisel to cut out the hole for the buckle prong.  The mini strap was attached to the underside of the main strap using three rivets.
The location of the mini strap was determined by wearing the quiver with the main strap tightened to a comfortable length and then locating the underarm strap in the most comfortable and effective place on the main strap and then marking the main strap with a soft pencil.
if you would like some info on hardening leather i would be willing to share what knowledge i have, i too am a novice leatherworker, but have learnt through trial and error some useful techniques. well done.
Thanks QSDR. I have done some water hardening of leather for arm bracers and guards for archery. It has been reasonably successful, and is quite good for molding leather to suit your body shape.
<p>Thank you for sharing your design. My 8 yr old nephew wants a back quiver so I may use this one. Thanks again.</p>
That's awesome I am picking up supplies today to make it
Thank you, this has been very helpful. I am making a quiver based on this design as a Christmas gift ;)
I like that, its really cool how you made it out of cow hide!
Very creative!
Looks awesome brother!
About This Instructable
42,535views
162favorites
License:
More by spopp17:Archery Back Quiver
Add instructable to:
