Step 5: Step 5: Prepare Dough and Cookie Sheet
After preparing both your wet and dry ingredients it is now time to add them together.
  • Take your cookie sheet and lightly coat the bottom of the pan
  • use your fingers to pat out dough onto cookie sheet to 1/2" thick
a. if you want to cut dough into squares you can and they should be appropriate for your dogs size.
*Important: Make sure when adding the wet ingredients you add as much water to the whole mixture to get them to form a ball. Don't add to much water or they will be very liquidity.
  • Place either the cut out cookies or just ball shaped cookies on the cookie sheet.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
