Introduction: Arduino 3D Printed Can Robot (one More Object Avoiding Robot) ​
Picture of Arduino 3D Printed Can Robot (one More Object Avoiding Robot)  ​
In this "how to" guide I will show you how to make your own 3D printed Can Robot with the Arduino UNO micro-controller.
This is a remake of the Attiny Canbot that I found at Thingiverse.com by Wingman94 (link here) .
I made my own circuit with ATmega328 IC and I add a buzzer to make a beep tone every time that robot finds an object in front of it. I didn't include the IR remote control function.
This little robot is powered by one 3.7V 500mAh rechargeable battery and can be charged from the builtin charging circuit .
Watch my little robot in action:
Project page - future updates can be found here.
Let's get started!
Step 1: What You Will Need - Hardware
Picture of What You Will Need - Hardware
For this project you will need:
  • Atmega328 (with Arduino UNO bootloader)
  • 28 dip socket
  • 16 MHz crystal oscillator
  • 2x22 pF capacitors
  • 10 kOhm resistor
  • 2 continuous rotation servo FS90R
  • HC-SR04 ultrasonic sensor
  • Buzzer
  • 3.7V 500mAh rechargeable battery
  • Charging circuit
  • On/Off micro switch
  • PCB prototype board
*You will also need a TTL to USB module or an Arduino UNO board for the programming procedure.
Tools: You will need a soldering iron and hot melt glue gun and of course a 3D printer.
Step 2: The Circuit
Picture of The Circuit
Take your time and make your circuit as small as you can so it can fit inside the can robot.
Step 3: The Code
Connect your circuit with TTL to USB module (or Arduino uno board - note - remove ATmega328) with 5 cables to the programming header. The pins RX and TX must be cross-connected. You can change the speed of your small robot by changing the "speedS=10" variable - line 14.
Download the code from this step and open it with Arduino IDE. Inside you will also find all necessary libraries.
Step 4: 3D Printing Files
Picture of 3D Printing Files
Here you will find the 3D files, download them from the official project page.
I would advice you to use support at your 3D printing procedure.
Step 5: Finally...
Picture of Finally...
It's time to use your hot melt glue gun, watch the above images for reference.
That's it!
I hope you liked this, let me know in the comments!
I would also like to see some photos with your new 3d printed robot!
LoganRodriguez (author)2018-01-05
what size PCB prototype board do i need
gefkuz made it! (author)2017-05-30
I just had a nrf24l01 to command it with a game pad. And I use a mini-pro arduino.
Thx
Mr innovative (author)2017-03-26
good one..very compact
Ardumotive_com (author)2017-03-25
Thank you!!!
sumondigi (author)2017-01-25
good concept
Ardumotive_com (author)sumondigi2017-03-25
Thank you!!!
ROBO HUB (author)2017-02-02
mini robot that avoids obstacles..great instructable..
Ardumotive_com (author)ROBO HUB2017-03-25
Thank you!!!
HeritierB (author)2017-03-23
Hey !!
Is it possible to pilot it ? With Android or an Iphone ?
I think it's an great idea to try !
Nice work !
Ardumotive_com (author)HeritierB2017-03-25
Hello, it is possible to add a bluetooth module, but it must be placed outside of main body.
Ardumotive_com (author)2017-02-01
Thank you!
Anirudh Ralhan (author)2017-01-24
Really cool!!!
Thanks!
PabloP22 (author)2017-01-24
GREAT !! But i tried to build my own and i can't , because the code don't open , can you upload another or send me by email (pa.echauri19@gmail.com)
Ardumotive_com (author)PabloP222017-01-25
Hello, if you can open the .zip file, you can copy-paste the code from this link into your Arduino IDE.
http://www.ardumotive.com/can-robot-en.html
About This Instructable
9,450views
141favorites
License:
More by Ardumotive_com:MIKE - Arduino Line Following Robot for Beginners "GRECO" - Arduino Object Avoiding Robotfor BeginnersArduino 3D Printed Digital Thermometer With DHT-22 Sensor
Add instructable to:
