3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Arduino 7 segment countdown timer
Step 3The build
The build
This project is quite complicated so you will need basic electronic skills.
First you will have to solder wires on the back to make the multiplexing circuit.
This can be done on a breadboard if your display is not SMD.
Secondy, solder on jumper wires to plug the display into the breadboard.
Thirdly, connect wires from the breadboard to the Arduino in this sequence:
Segment A: pin 7
Segment B: pin 8
Segment C: pin 4
Segment D: pin 3
Segment E: pin 2
Segment F: pin 6
Segment G: pin 5
Gnd1 via resistor: pin 11
Gnd2 via resistor: pin 9
3 comments
Oct 7, 2010. 2:35 AMFalconFour says:
You've got to add more detail to this. I'm having to make a lot of wiring guesswork here. "via resistor"? What value? I assume we're plugging these into digital pins, since there is no such thing as just Arduino "pin 6", etc...? Ground doesn't need a transistor? *shrug*...
Oct 7, 2010. 2:37 AMFalconFour says:
Also, nowhere in here states what segment is A-B-C-D-E-F-G... biggest bit of guesswork yet :(
Apr 7, 2011. 8:45 PMgranitepenguin says:
Most displays start with A on the top and then go clockwise, with G in the middle, so:
A - top
B - top right
C - bottom right
D - bottom
E - bottom left
F - top left
G - middle
You will probably need to look at the datasheet for whatever 7-segment component you have to tell what pins correspond to what segment, though.
Oct 8, 2009. 2:03 PMM4industries says:
I will rate this higher if you do one thing, EXPAND ON THIS!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:baharini
I'm a software developer, but I also love tinkering with electronics. My Instructables are all about Arduino.
