Introduction: Arduino AND Bluetooth HC-05 Connecting Easily
Hello Every body , This is my first artical on Instructable.com , I'm so happy for that , and I will start by How to connect arduino with bluetooth , I suffered a lot of problems when I try to connect it as the website and instructable artical did , So i decided To share my experience with You
The bluetooth module I will use today is HC-05 which is so familiar and cheap ,
Most tutorial on The website Connect the bluetooth with default Rx and Tx on the arduino Board , I faced a lot of problem and bluetooth didn't work will .
But arduino support something Called Software Serial , which allow You to change any arduino board pin to serial pin
http://arduino.cc/en/Reference/SoftwareSerial
so After reading this article you will be able to:
1) Connect arduino Board with PC By Bluetooth , to send and receive data .
2)Connect arduino Board with Any android device .
so you can send your information , Like Sensors reading , from arduino to PC Or android device , and you can build your Home automation system by bluetooth , and controlling your robot wirelessly
Step 1: Material and Connection
you need to do this experiment :
1) Arduino Board " I used Arduino Uno ".
2) Bluetooth module HC-05.
3)Solderless jumper.
4)Bread Board .
5)Battery 9V "Optional".
The connction between Arduino and bluetooth is like the schematic above
4)Bread Board .
Step 2: Connect Arduino With PC
We now want to send or receive Data between arduino and computer , first we need to make a Communication link to Definition arduino Board to the computer .
We will need a software called Tera Term to show the data received or what we want to send through it .
You can download Tera Term or any terminal emulator software , you can download Tera term from this link :
http://hp.vector.co.jp/authors/VA002416/ttermv14.zip
To make a link between your Arduino and bluetooth , do the following :
1) Go to the bluetooth icon , right click and select Add a Device
2) Search for new device , Our bluetooth module will appear as HC-05 , and add it
3) The pairing code will be 1234 .
4)after make a pairing , we can now program the arduino and upload a sketch to send or receive data from Computer.
Step 3: Arduino Code
As I mentioned before , I will use software serial library to make pin D10 & D11 As Tx & Rx instead of using the default Rx and tx " D0 &D1 On most arduino Board " .
this program below allow us to control LED connected to D13 To blink on/off , by press # 1 from PC Keyboard the LED blink on , and if we press 0 LED blink off !
To send the Control commands from Computer to arduino , Go to the tera term , Run it , and choose Serial , and select the bluetooth Serial from the list as Shown on the picture .
The code below :
// This program shown how to control arduino from PC Via Bluetooth
// Connect ...
// arduino>>bluetooth
// D11 >>> Rx
// D10 >>> Tx
//Written By Mohannad Rawashdeh
//for http://www.genotronex.com/
// you will need arduino 1.0.1 or higher to run this sketch
#include <SoftwareSerial.h>// import the serial library
SoftwareSerial Genotronex(10, 11); // RX, TX
int ledpin=13; // led on D13 will show blink on / off
int BluetoothData; // the data given from Computer
void setup() {
// put your setup code here, to run once:
Genotronex.begin(9600);
Genotronex.println("Bluetooth On please press 1 or 0 blink LED ..");
pinMode(ledpin,OUTPUT);
void loop() {
// put your main code here, to run repeatedly:
if (Genotronex.available()){
BluetoothData=Genotronex.read();
if(BluetoothData=='1'){ // if number 1 pressed ....
digitalWrite(ledpin,1);
Genotronex.println("LED On D13 ON ! ");
if (BluetoothData=='0'){// if number 0 pressed ....
digitalWrite(ledpin,0);
Genotronex.println("LED On D13 Off ! ");
delay(100);// prepare for next data ...
After uploading This sketch go to tera term and press 0 or 1 and see the results
This Video show the results of this code .
The code below :
// Connect ...
// D11 >>> Rx
// D10 >>> Tx
void setup() {
void loop() {
Step 4: Connect Arduino to Android Device
after we finished from connecting arduino with PC By bluetooth , let's move to how we can connect arduino To android device .
at first you need a terminal emulator on your andriod device to send or receive data to arduino .
You can download this app from Google play .
https://play.google.com/store/apps/details?id=arduino.bluetooth.terminal&feature=search_result#?t=W251bGwsMSwxLDEsImFyZHVpbm8uYmx1ZXRvb3RoLnRlcm1pbmFsIl0.
after that , you can use the same arduino Sketch and control LED Blinking on or Off from android device .
just type and t send #1 to make LED Blink on , or 0 to blink off .
this video below show how to control arduino I/O from android tablet .
Step 5: Receiving Data From Arduino
The last arduino Sketch that i wrote , used to send commands from PC Or android device to android , Now in this program i will use arduino to Calculate the time since the start of the program in second , and send it Via bluetooth to any pairing device .
the code below
// Connect ...
// D11 >>> Rx
// D10 >>> Tx
long previousMillis = 0; // will store last time LED was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000; // interval at which to blink (milliseconds)
int ledState = LOW; // ledState used to set the LED
long Counter=0; // counter will increase every 1 second
void setup() {
Genotronex.println("Bluetooth On please wait....");
void loop() {
unsigned long currentMillis = millis();
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
previousMillis = currentMillis;
Counter+=1;
Genotronex.println(Counter);
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
else
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledpin, ledState);
at the end , You can visit the orginal artical in arabic language on my website
Hope my first artical here is useful to you , thank you for your time ,
the code below
// Connect ...
// D11 >>> Rx
// D10 >>> Tx
void setup() {
void loop() {
Counter+=1;
ledState = HIGH;
else
ledState = LOW;
