Arduino - AT24C32 / DS1307 Real Time Clock 7 SEGment Display
3,549
15
15
Posted
Introduction: Arduino - AT24C32 / DS1307 Real Time Clock 7 SEGment Display
Hello world! Today i made a real time clock on a 4 digit display. The display i used is not really for clocks but it works, only the 2 dots are not in the right place, but you do not have to change anything in the code. You need a Library for this project. Follow the next step for the Schematic, Code & Parts list.
You need the following library SevSeg.h
check if you are using a common anode or cathode display
You can change this in the code at line 26
int displayType = COMMON_CATHODE; //change that to COMMON_ANODE
Other instructions on how to set time are in the code!
Step 1: Schematic, Code & Parts List.
Wire everything like the schematic and upload the code! Make sure the library is installed.
Parts list:
  • Arduino uno
  • AT24C32 / DS1307 real time clock ( I used the one on the picture above. There is also room for a temperature sensor like the LM35 on it)
  • 4 Digit 7 Segment Display
  • 4x 1 k Resistors. (Optional)
  • Jumper wires set MM/FM/MF
Good luck!
Check out our website! http://www.arduinosensors.nl
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    10 Comments
    display7seg.Begin(displayType, numberOfDigits, digit1, digit2, digit3, digit4, segA, segB, segC, segD, segE, segF, segG, segDP);
    Line erro.how to fix it
    hi vandenbrande. i've got the same problem. any suggestions?
    I got the following error messages while compiling
    Class SerSeg has no member named 'Begin', 'SetBrightness', 'DisplayString'
    Any comment, thanks
    i got error like
    exit status 1
    no matching function for call to 'SevSeg::begin(int&, int&, int&, int&, int&, int&, int&, int&, int&, int&, int&, int&, int&, int&)'
    yeah ,I have include the correct library i,e #include <SevSeg.h> but same thing happens
    What's the time format 12hrs or 24hrs
