Arduino Baby Sleep Monitor
4,288
52
6
Posted
Introduction: Arduino Baby Sleep Monitor
This is a proof of concept for an idea I had to use a baby monitor pressure pad to show how well a baby was sleeping.
By connecting the pressure pad to an arduino I was able to detect movement in a cot and trigger an LED to flash in time with the movement. I could then vary the LED's brightness depending on the intensity of the movement.
With a sensitive sensor this project could be used to show the baby breathing by causing the LED to fade in and out in time with the baby's breath.
Step 1: Materials
You will need:
  1. An Arduino UNO or compatible board
  2. An LED and appropriate resistor (I used 220R)
  3. A pressure pad. I used the mat from the following link, but you can also make your own (not demonstrated here). http://www.amazon.co.uk/Tommee-Tippee-Closer-Digit...
  4. A breadboard and wires.
  5. A resistor for the voltage divider (I used 10K).
Step 2: Wiring
You will need to create a simple voltage divider circuit as shown.
  1. Connect the output LED to digital pin 9 of the Arduino (don't forget the resistor!)
  2. Connect the sensor to analog pin 0.
There is a good tutorial explaining this concept on Jeremy Blum's YouTube channel:
Step 3: The Sketch
Upload the following to the Arduino:
int sensePin = 0; // Analog 0
int ledPin = 9; // Digital 9
int minRead = 99999;
int maxRead = 0;
void setup() {
pinMode(ledPin, OUTPUT);
void loop() {
// Read from sensor
int thisRead = analogRead(sensePin);
// Set max and min range (if appropriate)
if (thisRead < minRead) minRead = thisRead;
if (thisRead > maxRead) maxRead = thisRead;
// Set LED output
int ledLevel = map(thisRead, minRead, maxRead, 255, 0);
analogWrite(ledPin, ledLevel);
Step 4: Try It Out
This video shows the sensor in place, the flashing green light on the floor can be seen when the sensor is triggered.
The sketch you uploaded in the previous step automatically adjusts the LED brightness based on the minimum and maximum values received from the sensor. This means that the LED will always operate with the largest range of values possible. It also means that if it receives a spike from the sensor then it will remember that as the maximum value and will therefore need resetting.
Future improvements could include a time dependant range, so that spikes are 'forgotten' after a certain amount of time.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
6 Comments
This does indeed have some useful life monitoring potential, possibly even in the diagnosis of sleep apnea for both child and adult. Thanks for sharing the application and concept.
sleep apnea are monitored via chest movement, and oxygen in blood. Then it is corrected with the help of mpap machine.
Understood. In a sleep lab this is what is used, my point is that with some tweaks it may be useful in early diagnosis to determine if further study is indicated. At this juncture, I defer to the author as to what, if any, ancillary conditions this may be adaptable to, but it does seem like a platform with possible multiplicities of use.
It could be used for moving legs syndrome. It's when you move your legs as you sleep.
Love it, you could add a sound monitoring feature to avoid triggering a false alarm when the baby moves a bit.
Cheers
