loading
Step 7: Install Parallax LCD Library
Connect Arduino 5V, Ground, and TX (Arduino digital Pin 1) to the LCD socket. Read the labels on the LCD pins to make sure you have everything oriented correctly.
<p>For those asking about the mph calc:</p><p><strong>mph = (56.8*float(circumference))/float(timer);</strong></p><p>"circumference" is measured in inches</p><p>time per revolution of the wheel ("timer") is measured in milliseconds (0.001s)</p><p>miles/hr = 1/(inches per mile) * (miliseconds per hr) * (circumference / timer)</p><p>there are 63360 inches in a mile and 1000*60*60 = 3,600,000 ms in an hr:</p><p>mph = 1/63360*3600000*circumference/timer</p><p>mph = 56.8*circumference/timer</p><p><strong>to do this in km/hr:</strong></p><p>km/hr = 1/(inches per km) * (miliseconds per hr) * (circumference / timer)</p><p>km/hr = 1/39370*3600000*circumference/timer</p><p>km/hr = 91.4*circumference/timer</p>
<p>Instead of using a Parallax LCD, can i use an LCD with a I2C module attached to it?</p><p>Like this one: http://www.ebay.com/itm/IIC-I2C-TWI-SPI-Serial-Interface-Board-Module-Port-for-Arduino-1602LCD-Display-/161245616356?hash=item258afcd8e4:g:nf0AAOSwZQRYgIMA</p>
<p>here's a short video of the installation, to give you a better idea of what it is</p>
<p>Hi, I used this code to use my bike as a light switch (speed higher than 3mph, lights on, lower, lights off). It is an art installation, so the bike is static and a 5v relay acts as a switch for 40 3w led bulbs. Initially it worked fine, but after a while the lights didn't go off when people stopped pedalling. I know nothing about programming and posted this problem on the arduino forum. Tweaked a few things (made the variables in the interrupt volatile and declared the reed pinmode as INPUT_PULLUP. This made the thing more stable, but eventually the error happens anyway. The worst part is I can&acute;t predict whether it will happen after 3 or 6 hours or 2 or 20 users. If any of you guys have ANY clues as to what might be going on here, I'd really appreciate the help- THANKS!!!</p>
<p>hi amanda i will built like yours but i'am using magnetic sensor, can it work? </p>
<p>I modified the Schematic and Sketch for use with 128 x 64 Graphics LCD (with blue Background), I am using it with my Motor Cycle. It is giving good result. Further testing it, And seeking permission from Amanda to upload it as instructable on this site. Image of the final Display is attached. I am currently using it with the reed switch, but I have tested it with hall effect sensor, and it is working perfectly, (a little change will be made in sketch and schematic to use it with hall effect sensor).</p><p>Amanda!!! Can i upload it as instructable on this site?</p>
<p>awesome! yeah go for it!</p>
<p>Thanks</p>
<p>I'm curious if someone could answer this question for me (outside the OP) I use the code above from Step 11. if my reed makes just 1 contact (1 iteration) the MPH displayed is 47 mph. Even if I slowly move the wheel it is always 47 or 50 mph. Can someone explain why and how I can make it more realistic?</p><p>I noticed in her console outputs that those figures are about what I am getting.</p>
<p> I commented out the first time this line was used and it seemed to fix it.</p><p>reedCounter -= 1;//decrement reedCounter</p><p>I don't think you won't to drop the counter if the reed sensor is closed and the bike is not moving.</p>
gotta say thanks for the great idea and the code. used a 12c lcd, added a smoothing section of the code to average out some of the results. put it on my four wheeler and love it.
<p>Could I use 3 x 7 segment led digits for my read out as these are large (5&quot;) </p>
<p>What things should i change to use it in km/h? And whats that 56.8 in the code?</p>
<p>Hi, have you figured out what 56.8 is? I also want to use it in km/h, but don't have no idea what this is.</p>
<p>Change it to 91.44 for km/h.</p><p>Calculation: 1 inch/second = 2,54 cm/s = 0.09144 km/h = 91.44 inch/ms.</p><p>Or just multiply 56.8 by 1.6090712742981 (= 19.40)</p>
<p>1 inch/second is 0.0568 mph therefore 1 inch/millisecond = 56.8 mph</p>
<p>Hi Amanda ! I Made it, but I just to know how did you madethe calcul for mph?( </p><p>mph = (56.8*float(circumference))/float(timer);//calculate miles per hour ) ) I don't understand ?!! :(</p><p>And Ihave another question : how can I do if I only want to print RPM on the screen ?</p>
<p>can anyone explain the purpose of the reed counter ? </p>
<p>It is working like a rpm sensor. Every time wheel makes one turn, magnet closes the reed switch and this pulse goes to input pin of arduino. Arduino counts every pulse and convert it to speed with built-in code.</p>
<p>Hi Amanda, very helpful tutorial! Question for you... I'm trying to use this for measuring speed and distance of my son's hamster wheel. And will try to use a light sensor and LED to measure the revolutions of the wheel (no wires for the hamster to chew). For now just testing the code with a pushbutton switch to simulate RPMs. The radius of the wheel is 4.25 inches. With low RPMs (between 1 and 2 revs per second), I get a fixed speed of 15.02mph. Higher revs start to give me fluctuating speeds as expected. When RPMs drop to 0, it shows a speed of 0.002 mph (never 0.00). Any suggestions on how to fix it? Thanks in advance!</p>
<p>A light sensor sends a HIGH signal when there is no light. So, you need to add a &quot;!&quot; somewhere. I think if (!reedVal</p>
<p>Made it, not exactly the same but still working. Great!!</p>
<p>Hello,</p><p>i am workind on something similar, he differences are:</p><p>- i have a line follower sensor on digital pin 2</p><p>- i have a black and white stripe with 20 mm between 2 white stripes</p><p>- i need the output on the serial monitor, and not on the lcd.</p><p>i have put up a sketch, but i have some issues with the time.</p><p>i need to:</p><p>- start the counting every time the pin 2 changes (the sensor has moved) and count the millis until next pin 2 changes, and have the speed. at the end, if the pin 2 does not changes for 1 sec, the program stop's</p><p>can someone help me?</p><p>i have this sketch until now:</p><p>// Constante:</p><p>const int buttonPin = 2; // pinul digital pentru senzorul de linie</p><p>// Variabile:</p><p>int buttonPushCounter = 0; // counter numar impulsuri (1 sau 0)</p><p>int buttonState = 0; // starea actuala a senzorului de linie (1 sau zero)</p><p>int lastButtonState = 0; // starea anterioara a senzorului de linie (1 sau zero)</p><p>long time = 0;</p><p>void setup() {</p><p> // inititalizeaza intrarea pentru senzorul de linie:</p><p> pinMode(buttonPin, INPUT);</p><p> // initializeaza comunicatia seriala:</p><p> Serial.begin(115200);</p><p> Serial.println(&quot;________________________&quot;);</p><p> Serial.println(&quot;Program test&quot;);</p><p> Serial.println(&quot;________________________&quot;);</p><p>}</p><p>void loop() {</p><p> // citeste intrarea senzorului de linie:</p><p> buttonState = digitalRead(buttonPin);</p><p> time = 0; </p><p> // compara starea butonului actuala cu cea anterioara</p><p> if (buttonState != lastButtonState) {</p><p> // if the state has changed, increment the counter</p><p> if (buttonState == HIGH) {</p><p> // if the current state is HIGH then the button</p><p> // wend from off to on:</p><p> buttonPushCounter++;</p><p> time++;</p><p> }</p><p>Serial.print(&quot;Deplasare [mm]: &quot;);</p><p>Serial.println(buttonPushCounter*20);</p><p> Serial.print(&quot;Timp [s]: &quot;);</p><p> time = millis();</p><p> //prints time since program started</p><p> Serial.println(time/1000);</p><p> Serial.print(&quot;Viteza [mm/s]: &quot;);</p><p> Serial.println((buttonPushCounter*20)/(time/1000));</p><p> Serial.println(&quot;________________________&quot;);</p><p> // Delay a little bit to avoid bouncing</p><p> delay(1);</p><p> }</p><p> // save the current state as the last state,</p><p> //for next time through the loop</p><p> lastButtonState = buttonState;</p><p> time = 0;</p><p>}</p>
<p>can anyone explain the purpose of the reed counter and max reed counter? is it the max time for one rotation or something to that effect? </p>
<p>I've tried using this code to measure windspeed on an anemometer for a project of mine. it's a rotating magnet and a reed switch so it's the same principle. The reed test works fine. i've changed the radius (0.87 inches) to fit with my windspeed sensor. However when i upload the code, the serial port view just gives me 0's for MPH for the first reading then a steady steam of 28.21 MPH. Any ideas?</p>
<p>Did you manage to work this out in the end b3nz1? I'm doing similar.</p>
<p>I had the same problem. What i found was that my reed switch was dong one of 3 things; 1.chattering when the magnet was passed over it. To fix this I just increased the maxreedcounter value to 150 or 200ms. The original 100ms wasnt enough to sstop the second switch cycle induced when the switch left the magnetic field. 2. If i passed the magnet too slowly over the switch the switch would stay closed for more then 1 sample cycle, so the maximum speed reading would output. ;so eithur move the magnet faster over the switch or find a mag with a more concentrated field. 3. My first reed switch was normally closed, my own stupitidy there... get one thats n/o. goodluck</p><p>have u found out what that 56.8 value is? im tryna chang the code and lost where that comes from.</p>
<p>hi,have you figured out what the 56.8 value is? I am also doing a similar project, but I want to show the speed in km per hour. I have changed something, but still have no idea what 56.8 is.</p>
<p>Hello Amanda! Im trying to do something similar to your project, but I would like to use a hall effect sensor as it can be used at higher frequencies, how would the code change to accomodate the Hall Effect sensor?</p>
<p>for me the code is not correct. The pulse should be captured when reedVal and reedcounter=maxreedcounter not when reedcounter=0</p>
<p>Hi Amanda, I have a problem with your's code on my stationary bike. Speed calculated by arduino is very low (sth like 1 - 5 km/h max) and I don't know what is wrong :/ I changed only radius for 0.12 m (this is radius of my stationary bike wheel). Is that any problem with fact then my bike have a belt drive ? Something like this electronics.stackexchange.com/questions/140063/measure-the-speed-of-a-stationary-bike-with-belt-drive ? Please help!</p>
<p>A little late, but FYI the wheel size should be in Inches not meters</p>
<p>Hi Amanda</p><p>Great instructable! I'm trying to use the same principles in a slightly different project in which I am importing a library what already uses the Timer1 interrupt - what would be the implications of using Timer 2 as the interrupt in the code to measure the speed of the wheel in terms of accuracy of measurement? And is it simply a case of amending the timer setup to use TCCR2A etc.?</p>
<p>Hello! <br><br>Can anyone share code for this but with classic display? I dont have experience with programming so i need some help. Thanks for helping.</p>
<p> hOLA EXELENTE PROYECTO YO INTENTO USARLO PARA OTRO PYOYRCTO QUE PARTE DE UN VELOCIMETRO PODRIAS PUBLICAR EL DIAGRAMA DE CONECCION </p>
<p>hi</p><p>which other lcd is available to use?</p>
<p>I have a similar code. Initially, I was using the capacitive sensor technique but I realized that it is severely affected by external conditions. I am thinking of using the reed switch. For measuring distances, has anyone faced problems with the reed switch method ?</p>
<p>hahaha amazing!! Thanks for sharing!</p>
hello..<br> <br> im using this LCD<br> <a href="http://www.engineersgarage.com/electronic-components/16x2-lcd-module-datasheet" rel="nofollow">http://www.engineersgarage.com/electronic-components/16x2-lcd-module-datasheet</a><br> <br> is there anything i have to modify?
<p>this lcd does not support serial communication, you can get it to work, but you will have to read the datasheet and make some changes to the code.</p>
<p>Could you please help me with the code for this LCD display??? Please (Serial communication 16x2 display) Thank You</p>
<p>See this article:<br>https://www.instructables.com/id/Connecting-an-LCD-to-the-Arduino/</p>
cool
<p>Hi. Can I still use the code for reed if I change the reed switch to hall effect sensor? Because my reed switch can't get accurate mph(double / triple of the actual speed) when the speed is slow</p>
but it does work when it's fast?
About This Instructable
316,163views
318favorites
License:
Bio: I'm a grad student at the Center for Bits and Atoms at MIT Media Lab. Before that I worked at Instructables, writing code for ... More »
More by amandaghassaei:OTCA Metapixel - Conway's Game of Life "9 Degrees of Freedom" IMU Twitter Controlled Pet Feeder
Add instructable to:
