3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Arduino Binary Alarm Clock
Step 3Code Structure
Code Structure
I have divided the code for the clock into functions, one for each important bit of functionality. The functions are in separate tabs in the sketch. these are then run in the main loop:
void loop()
  clock();       // keep track of time, i.e. update hours, minutes and seconds variables as needed.
  display();   // display the time, or the alarm time, depending on the state of the settings switch.
  alarm();     // checks if it's time for the alarm  to start.
  update_buttons_state();   // checks if the buttons and touch sensor states has changed
  buttons();  // does what the buttons should do
The variables that are needed by several functions are declared in the first tab (where setup() and loop() is) and the variables that are needed only by one function is declared in the same tab as that function.
If you change the DEBUG constant to 1 you will get some output via serial that can be good for troubleshooting, e.g. the time and what value the touchsensor returns.
I have tried to comment and make the code understandable but if you have questions or suggestions for improvements just leave a comment.
Here are the pins I used for the different parts:
- 2 and 4:  Touchsensor (4 is the send pin, 2 is recieve)
- 6              Hour button
- 5              Minute button
- 7              Switch
- 14-18      Display hour pins
- 8-13        Display minute pins
You can use whatever pins you want, just change in the code accordingly.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:njakol
