Arduino Binary Clock (hours, Minutes and Seconds)
10,274
24
5
Posted
Introduction: Arduino Binary Clock (hours, Minutes and Seconds)
Hello everyone; I was looking for this project for a long time.  Finally I it it together with a lot of effort.  For this project you will need:
1-   Arduino Uno ($30 from Radio Shack)
2-   RTC DS1307 (like $2 from EBay)
3-   2 Shift Registers 74HC595 (like $1 eachh from Ebay)
4-   16 leds
5-   16 330 hom resistors
6-   Breadboards
7-   jumpers
The clock will display the hours using the first 4 leds, then the minutes using the next 6 leds and finally the seconds using the las 6 leds.
There is a better explanation from the original project here (as well as other cool projects): http://www.multiwingspan.co.uk/arduino.php?page=bclock
Step 1: The Schematics
Here is the design; mounted in two full breadboards! (Make sure you've got all the connections right, fail to to so will give you a few days of headache; it happened to me!)
Step 2: The Code (from Http://www.multiwingspan.co.uk by M Atkinson)
//orignal code made by M Atkinson, please check his website http://www.multiwingspan.co.uk
//few minor modifications made by cronos_80@hotmail.com
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
int datapin = 2;
int clockpin = 3;
int latchpin = 4;
int datapin2 = 8;
int clockpin2 = 9;
int latchpin2= 10;
void setup()
  Serial.begin(57600);
  Wire.begin();
  RTC.begin();
  if (! RTC.isrunning()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    //RTC.adjust(DateTime(__DATE__, __TIME__));
  pinMode(datapin, OUTPUT);
  pinMode(clockpin, OUTPUT);
  pinMode(latchpin, OUTPUT);
  pinMode(datapin2, OUTPUT);
  pinMode(clockpin2, OUTPUT);
  pinMode(latchpin2, OUTPUT);
void loop()
  DateTime now = RTC.now();
  // All used for checking the time of the clock
  // This section can be removed when everything is working
  Serial.print(now.hour(), DEC);
  Serial.print(':');
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  Serial.print(now.second(), DEC);
  Serial.println();
  // End of section that can be removed
  int mins = now.minute();
  int secs = now.second();
  int hr = now.hour();
  // convert to 12 hour time
  if (hr>12)
    hr = hr-12;
  // variables to describe pattern of on lights
  byte data1 = 0;
  byte data2 = 0;
  // encode the time
  // hr = 1st four bits controlled by the first shift register
  for (int i =0;i<4;i++)
    if (bitRead(hr,i)==1)
      bitWrite(data1,3-i,1);
  // mins on the first shift register (last 4 leds)
  for (int i =2;i<6;i++)
    if (bitRead(mins,i)==1)
      bitWrite(data1,9-i,1);
  // mins on the second shift register (first 2 leds)
  for (int i =0;i<2;i++)
      bitWrite(data2,1-i,1);
  // seconds, controlled by the second shift register (all 6 leds)
  for (int i =2;i<8;i++)
    if (bitRead(secs,i-2)==1)
      bitWrite(data2,9-i,1);
  // output the information
  writeByte(data1,1);
  writeByte(data2,2);
  // a pause every one second for the serial monitor output
  delay(1000);
void writeByte(byte data, byte set)
  int d,c,l;
  if (set==1)
    d = 2;
    c = 3;
    l = 4;
  else if (set==2)
    d = 8;
    c = 9;
    l = 10;
  shiftOut(d, c, MSBFIRST, data);
  // toggle the latch pin so that the data appears as an output
  digitalWrite(l, HIGH);
  digitalWrite(l, LOW);
Step 3: The RTClib
For this project you will need the RTClib in order to run the program properly.  You can download it here:
http://arduino-info.wikispaces.com/DS1307_RealTime_Clock_Brick
Your RTC will come loaded with the time; sometimes with local time from China; to change the time, go to this website http://bildr.org/2011/03/ds1307-arduino/, connect your RTC (the website will show you the diagram) and run the following code:
//Arduino 1.0+ Only
//Arduino 1.0+ Only
#include "Wire.h"
#define DS1307_ADDRESS 0x68
byte zero = 0x00; //workaround for issue #527
void setup(){
  Wire.begin();
  Serial.begin(9600);
  setDateTime(); //MUST CONFIGURE IN FUNCTION
void loop(){
  printDate();
  delay(1000);
void setDateTime(){
  //edit here the date and time
  byte second =      20; //0-59
  byte minute =      27; //0-59
  byte hour =        22; //0-23
  byte weekDay =     26; //1-7
  byte monthDay =    22; //1-31
  byte month =       11; //1-12
  byte year  =       13; //0-99
  Wire.beginTransmission(DS1307_ADDRESS);
  Wire.write(zero); //stop Oscillator
  Wire.write(decToBcd(second));
  Wire.write(decToBcd(minute));
  Wire.write(decToBcd(hour));
  Wire.write(decToBcd(weekDay));
  Wire.write(decToBcd(monthDay));
  Wire.write(decToBcd(month));
  Wire.write(decToBcd(year));
  Wire.write(zero); //start
  Wire.endTransmission();
byte decToBcd(byte val){
// Convert normal decimal numbers to binary coded decimal
  return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val)  {
// Convert binary coded decimal to normal decimal numbers
  return ( (val/16*10) + (val%16) );
void printDate(){
  // Reset the register pointer
  Wire.write(zero);
  Wire.requestFrom(DS1307_ADDRESS, 7);
  int second = bcdToDec(Wire.read());
  int minute = bcdToDec(Wire.read());
  int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
  int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
  int monthDay = bcdToDec(Wire.read());
  int month = bcdToDec(Wire.read());
  int year = bcdToDec(Wire.read());
  //print the date EG   3/1/11 23:59:59
  Serial.print(month);
  Serial.print("/");
  Serial.print(monthDay);
  Serial.print("/");
  Serial.print(year);
  Serial.print(" ");
  Serial.print(hour);
  Serial.print(":");
  Serial.print(minute);
  Serial.print(":");
  Serial.println(second);
Step 4: Video of the Clock in Action!
Here is a short video of the completed project, I hope you like it!!!!!
http://youtu.be/ZCct-TuGMrQ
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
5 Comments
any tips to get the program running on an arduino nano. It uploads just fine and I can see the correct time on the serial monitor. The hours work but the mins or seconds don't light up. Is there a difference in the pin layout between the two boards?
Note: You can use unused analog pins (A0~A6) as extra digital output.
why my arduino shows problem to upload programm
I need more information!
