Arduino Bluetooth Communicated Led
Published
Introduction: Arduino Bluetooth Communicated Led
u can use this project to trigger on any device of 5 v using just the output of this circuit which can be used for home automation
a tutorial on home automation using relay will be posted soon
u can also use relays for higher power supply
u will need arduino uno
hc-o5 bluetooth module
and any out put eg led
Step 1: Uploading the Program
upload the program on your arduino before because u cannot upload a code in arduino if the tx rx pins r connected
Step 2: Make the Connection
connect the led
the longer or +ve pin to 13
the -ve to ground which is just adjacent
connect the hc-05 to your board
vcc or 5v to 5v pin of arduino
ground to ground
tx to rx (in my board tx is pin 1 and rx in pin0 )
rx to tx
Step 3: Using the App
u will have to download bluetooth terminal
u have to first connect the device to the module and then u r ready
when u send small alphabet 'a' the LED turns on and when u send small 'b' LED turns off
innovate yourself and use it as per u want
pls vote me in the contest
i will make a tutorial on home automation using relays soon with the same project
Makerspace Contest
Fourth Prize in the
Makerspace Contest
    • Clocks Contest
      Clocks Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
