Arduino Bluetooth Control Basic Tutorial
8,270
172
7
Published
Introduction: Arduino Bluetooth Control Basic Tutorial
In this tutorial I'll show you, How to control Arduino with your smart phone using, My app developed with app inventor 2.
Step 1: Things You Need
Hardware
    • Arduino
    • Bluetooth Module HC 05/06
    • LED
    • 220Ω Resistor
    • 2.2KΩ Resistor
    • 4.7Ω Resistor
    • Android device
    Software
    • Arduino IDE
    • App Inventor 2 (for create your app).
    Step 2: Watch the Video Tutorial
    Step 3: Schematics
    The circuit is so simple:
    Arduino Pins: Breadboard: Resistor: Bluetooth Module:
    • RX (Pin 0)--------------------------2.2KΩ--------------TX
    • TX (Pin 1)------------------------------------------------RX
    • 5v-----------------------------------------------------------5v
    • Gnd--------------------------------------------------------Gnd
    • Pin2,Gnd-------Led----------------220Ω
    • RX------------------------------------4.7Ω---------------Gnd
    Notes and Tips: You need to remove the RX and TX cables when you’re uploading the sketch to your Arduino.
    If the HC-05 Bluetooth Module asks for a password, It’s’1234′.
    Sometimes people connect the TX from the bluetooth module to the TX of the Arduino… that’s wrong and it won’t work. Make sure you connect it properly, the TX into RX and the RX into the TX.
    Step 4: Arduino Sketch
    int ledblue=2;
    int tx=1;
    int rx=0;
    char inSerial[15];
    void setup(){ Serial.begin(9600);
    pinMode(ledblue, OUTPUT);
    pinMode(tx, OUTPUT);
    pinMode(rx, INPUT);
    allpinslow();
    void loop()
    { int i=0;
    int m=0;
    delay(500);
    if (Serial.available() > 0) { while (Serial.available() > 0) { inSerial[i]=Serial.read();
    i++; }
    inSerial[i]='\0';
    Check_Protocol(inSerial); }}
    void allpinslow() { digitalWrite(ledblue, HIGH);
    digitalWrite(ledblue, LOW); } void Check_Protocol(char inStr[]){ int i=0;
    int m=0;
    Serial.println(inStr);
    if(!strcmp(inStr,"2off")){ //Led Off allpinslow();
    digitalWrite(ledblue, LOW); Serial.println("Blue Off");
    for(m=0;m<11;m++){ inStr[m]=0;} i=0;} if(!strcmp(inStr,"2on")){ //Led on allpinslow();
    Serial.println("Blue on"); for(m=0;m<11;m++){ inStr[m]=0;} i=0;} else{ for(m=0;m<11;m++){ inStr[m]=0; } i=0;
    Step 5: Android Application
    App Inventor 2 project file:Designer and Blocks code.
      • Woodworking Contest
        Woodworking Contest
      • Planter Challenge
        Planter Challenge
      • Casting Contest
        Casting Contest
      7 Comments
      Hi I couldn't get this to work, the LED will turn on and off if I use arudino serial monitor, and the phones blue tooth finds and connects to the module, there just seems to be no communication between the blue tooth module an the arduino. Ive tried 2 different HC6 modules and with and without the voltage divider. Any ideas?
      can you upload an .apk for testing?
      The 4k7 and the 2k2 resistors are a voltage divider to drop the 5V output from the Uno's Tx pin to a lower voltage for the Bluetooth module which is not 5V tolerant. (5x 4.7/(4.7+2.2) = 3.4V)
      It is connected to gnd and tx of the HC06 board.
      I like the idea of a basic tutorial to teach others. I would of liked to have seen cleaner arduino code for a tutorial. You have several lines of code that are not needed or do nothing. Pins 0 and 1 don't need pinMode. Serial.begin takes care of that. Your 2 Serial.println send data back over BT but your app is not programmed to receive it. Again I like the idea. Thanks
      Thanks for sharing a beginner tutorial!
