loading
This project will show you how to make a wireless upload Arduino code from your Computer via Bluetooth.
Hardware components:
HC-05 bluetooth moduel *
Resistor 2.21k ohm *1
Resistor 10k ohm *1
resistor 15K *1
100nf capacitor *1
Arduino UNO & Genuino UNO *1
prototyping shield *1
Bluetooth *1
Software:
Arduino IDE
Hand tools and fabr09507 01
Soldering ironication machines:
Step 1: Breadboard the Bluetooth Module Setup Circuit
•The Bluetooth module used in this project is the HC-05. It is inexpensive and one of the most common modules you'll see in a lot of other projects. The HC-05 is sold bare or mounted to a breakout board. You want one on a 6-pin breakout board. You can find them for sale on eBay and Amazon. The datasheet for the module is here.
•Using a breadboard, temporarily wire the HC-05 Bluetooth module per the schematic.
•With 3.3v on the Key pin, the module will enter 38400 baud command mode and will accept AT commands. The Key pin must be connected to 3.3v when the module is powered on. If it is connected afterwards, the module will enter command mode at the default baud rate (as set by the 'AT+UART=' command or 9600 baud from the factory).
Step 2: Upload the Setup Sketch
Get the sketch from here and upload it to your Arduino.
serialloop.zip
Step 3: Run the Setup Sketch and Enter Serial Commands
Open the serial console and make sure the baud rate is set to 9600 and line endings is set to be "Both NL & CR"
•Enter the following AT commands into the serial console one by one:
AT+ORGL
AT+ROLE=0
AT+POLAR=1,0
AT+UART=115200,0,0
AT+INIT
In order, these commands tell the module to reset to factory settings, switch to slave role (transparent serial bridge), set pin 32 low on Bluetooth connection, change baud rate to match the Arduino Uno programming rate, and to initialize. •Disconnect 3.3v from the Key pin and cycle the power to the module. It will now be running at 115200 baud and be in pairing mode.
Step 4: Setup the Bluetooth Module in Windows
  • From the Control Panel select Add a Device.
  • Add the Bluetooth module.
  • Select enter pairing code option.
Step 5: Setup the Bluetooth Module in Windows
•Enter "1234" for the pairing code.
•At the Add a device success window, click Close.
•Device ready to use. The OS will create two serial COM ports associated with the device. Always use the one with the lower number.
Step 6: Solder a Jumper Onto the Bluetooth Module
DIY Arduino Bluetooth Programming Shield•Disassemble the breadboarded circuit. Solder a jumper wire directly to the HC-05's Pin 32.
•Don't forget to use flux.
•You may want to use hot glue or tape to protect the joint.
Step 7: Build the Programmer Circuit
•Build the programmer circuit onto the prototyping shield.
•Solder on a female header for the Bluetooth module if you want to be able to easily remove it later.
Step 8: Program the Arduino With Bluetooth
Power on the Arduino from a battery or AC adapter.
•In the Arduino IDE, choose the serial port of the Bluetooth module (the lower valued one of the two(21 and 25) and then upload a sketch like normal.
Step 9: SCHEMATICS
This is the circuit after changing the command on the bluetooth module with the arduino Download
Build the programmer circuit onto the prototyping shield. Solder on a female header for the Bluetooth module if you want to be able to easily remove it later.
Pin 32 Download
connect the pin 32 like the circuit diagramme with the arduino
Step 10: CODE
serialloop.zipC/C++
DOWNLOAD
About This Instructable
529views
26favorites
License:
More by Adriannn:Programming ESP8266 With Arduino How to Make a Rings Puzzle With Arduino Arduino Bluetooth Programming Shield
Add instructable to:
