Remove these ads by
Signing UpStep 1Gather Necessary Supplies and Tools
40-Pin 2.54mm (0.1") Header Pin Strip x2 (Digikey, Newark, Local Electronics Shop)
10cm (4") 22AWG Black Stranded Wire
The header pins I used were 20cm long. These longer pins may be difficult to find, but you should be able to order them from an online supplier. The standard length (~8mm) can be used, however they may make things a bit tight.
Tools:
- Soldering Iron
- Solder
- Arduino
- Wire Strippers
- Side Cutters
http://www.lmgtfy.com/?q=right+angle+header+connector
Since I usually have a ten or so projects on the go at once, I was frequently moving my Arduino from board-to-board, and found the right-angle to work better for this purpose. The Arduino weighs so little that it doesn't seem to cause any top-heaviness issues.
I'm not knocking the idea though - give it a whirl :-)
