loading
loading
Picture of Arduino Breathalyzer
What is a breathalyzer you may ask? It is a device for estimating blood alcohol content (BAC) from a breath sample.In simple terms it is a device to test weather a person is drunk or not. As the title suggests it runs on the arduino.Our breathalyzer uses the MQ-3 alcohol sensor from sparkfun.It is a simple and fun to do project.
This instructable explains how to create your own breathalyzer , making a shield for the arduino , putting the breathalyzer in a box, and making some changes to your breathalyzer.
This Breathalyzer is not meant to be used as a means of breathalyzing. The MQ-3 is not accurate enough to register exact BAC and is sensitive to temperature and humidity.Never drink and drive and if you do call me =D .
Step 1: Parts & Tools
Picture of Parts & Tools
Parts:
~ Arduino Uno - Sparkfun.com
~ MQ-3 Alcohol Sensor - Sparkfun.com
~ 100k Ohm Potentiometer - Sparkfun.com
~ 330 Ohm Resistor - Sparkfun.com
~ 5 x Green LED's - Sparkfun.com
~ 3 x Yellow LED's - Sparkfun.conm
~ 2 x Red LED's - Sparkfun.com
~ 7805 Voltage Regulator - Local Electronics Store
~ 1000 uf Capacitor - Local Electronics Store
~ 2 x 9v Batteries - Local Electronics Store
Tools:
~ Soldering Iron - Sparkfun.com
~ Solder Wire - Sparkfun.com
~ Jumper Wires -Sparkfun.com
~ Protoboard - Sparkfun.com
~ Project Box - Local Electronics Store
~ Inhaler Tube - I Found It In My House
Step 2: The Chemistry
Picture of The Chemistry
When the user exhales into a breath analyzer, any ethanol present in their breath is oxidized to acetic acid at the anode:
CH3CH2OH(g) + H2O(l) → CH3CO2H(l) + 4H+(aq) + 4e-
At the cathode, atmospheric oxygen is reduced:
O2(g) + 4H+(aq) + 4e- → 2H2O(l)
The overall reaction is the oxidation of ethanol to acetic acid and water.
CH3CH2OH(l) + O2(g) → CH3COOH(l) + H2O(l)
The electrical current produced by this reaction is measured by a microprocessor, and displayed as an approximation of overall blood alcohol content (BAC) by the Alcosensor.
blackcamo1 month ago
you can get all the parts for a fraction of price..
https://sites.google.com/site/arduinouk
redinside2 months ago
Hi, I bought LM393-MQ-3 Gas Sensor module. How should I connect this module to Arduino and what kind of conversion and calibration should I do to get the level of BAC and display it on a LCD.
Thank you very much
philbot10 months ago
I have tried this a few times but I can't get anything to work, all of the LEDs turn on immediately and just stay on, any ideas on what I'm doing wrong?
pasteler01 year ago
The code was taken from: http://www.danielandrade.net/2010/03/07/building-an-breathalyzer-with-mq-3-and-arduino/
Should at least leave the header...
Bot1398 (author)  pasteler011 months ago
Mentioned the header sorry for not mentioning it before
djoy21 year ago
can put a LCD display on this project and how? could you please help for my project
djoy21 year ago
can i use atmega328 instead?
mattgilbert2 years ago
As pointed out in the comments on this page, Sensor pin B needs to be connected to VCC, not GND. This is what the sample circuit in the datasheet shows, and a student of mine couldn't get the project to work until we did it this way.
nodoubtman2 years ago
Hi! How the MQ-3 SENSOR is hoocked up on the board?
thank you!
marC:)
Bot1398 (author)  nodoubtman2 years ago
I have attached the schematic on step 5
The ed2 years ago
I wanted to ask, is 6 volts from 4 AA batteries too much for the sensor? Can I use 4.5 volts instead?
Bot1398 (author)  The ed2 years ago
Yes, You should use 4.5 volts instead always be on the safer side
The ed Bot13982 years ago
Thanks a lot. I have since gotten a DC-DC converter and got the 5 volts I needed. But anyways thanks for the reply
nice one what is the cost after shipping to india??
Bot1398 (author)  Pranavthegreat2 years ago
They take 11$ to ship to india but its worth it.
techxpert2 years ago
very nice! i've been looking for a breathalyser for a long time now and this is the cheapest except the arduino uno try this one instead :)
http://www.dealextreme.com/p/arduino-uno-rev3-development-board-120464?item=15
