Introduction: Arduino - Button With LED
Turns ON and OFF a light LED, when pressing a pushbutton.
Step 1: Hardware Required
Picture of Hardware Required
  • Arduino Uno
  • LED
  • Button
  • 220 and 10k ohm resistors
  • Wires
  • Breadboard
Step 2: LED Connections
Picture of LED Connections
  1. LED attach to board
  2. Resistor (220 ohm) connect to LED's long leg (+)
  3. The wire connect to resistor empty leg
  4. After that, same wire connect to digital pin from resistor
  5. The wire connect to LED's short leg (-), after that same wire connect to ground
Step 3: Pushbutton Connections
Picture of Pushbutton Connections
  • The button attach to board
  • 10k resistor connect to button leg
  • The wire connect to resistor empty leg, after that same wire connect to ground
  • The wire connect to button's other leg, after that same wire connect to +5V
  • The yellow wire connect to button's top leg, after that connect to digital pin
Step 4: Code
Picture of Code
const int ledPin = 2;
const int buttonPin = 4;
int buttonState = 0;
void setup() {
Serial.begin(9600);
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT);
void loop() {
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
digitalWrite(ledPin, HIGH);
Serial.println("LED ON +++++++");
else {
digitalWrite(ledPin, LOW);
Serial.println("LED OFF -------");
Step 5: If It Helps, Please Subscribe
Picture of If It Helps, Please Subscribe
First of all, I would like to thank you for reading this guide ! I hope it helps you.
If you want to support me, you can subscribe my channel and watch my videos.
Mert Arduino Tutorial & Projects
Nic-SMD (author)2017-09-27
Hello friend,
I need to make a project but my zero knowledge in programming does not allow me to build it. For someone with knowledge and experience may be a project for children :).
I am wondering if you can help me on that.. please!
Micky Flanagan (author)2016-11-18
Maybe it's not yours or something but the arduino uno on the first page looks like a knockoff.
im with you
Sorry. I don't understand you :/ What are you talking about?
Alejandro2099 (author)2017-08-28
im with Micky Flanagan
i dont know what i did wrong and it didnt work
About This Instructable
6,733views
51favorites
License:
Bio: For more project and tutorial visit my YouTube channel Mert Arduino and Raspberry Pi
More by MertArduino:XY Plotter Drawing Robot | Arduino | PolargraphArduino - Balance - Balancing Robot | How to Make?Arduino - MPU6050 GY521 - 6 Axis Accelerometer + Gyro (3D Simulation With Processing)
Add instructable to:
