loading
Hi, this is my first instructable and I hope to do more.
This project was for 'Creative Electronics', a Beng Electronics Engineering 4th year module at the University of Málaga, School of Telecommunications.
http://www.etsit.uma.es/
It's a cnc using Arduino UNO R3 , GCode Sender and GRBL. The cnc is made of wood thanks to the help of my father. It has taken us many hours to do the mechanical part however the electronic part is faster to do, but is very gratifying. I based my project on these videos and I have received much support from the author of the first video.
[Reproducir video]
[Reproducir video]
The total cost of the project is about 450€.
Step 1: Materials and components
From experience I recommend buying all the necessary materials before starting the realization of any project.
Materials and components:
  • Laminated Wood
  • Screwed Steel rods
  • Steel bars
  • Ball bearings
  • Nuts
  • Screws
  • Stepper motors (in my case Nema 23)
  • Stepper motors drivers TB6560
  • Switching power supply 24V 15A
  • Arduino UNO R3
  • Some wires
  • Nylon and metal bearings
Step 2: X axis
To build the base we have been cut several wooden boards which have made holes and blind holes. These tables form the support of the machine. The screwed steel rods operates as a worm drive. The blind holes serve as a stop for the steel bars that act as guides for the x-axis, in the middle, we put the screwed steel bar, that when turning, generates displacement in the x-axis. Above, we have put a wooden board greater weight and thickness for stability.
Step 3: Y axis
Bridge construction (y-axis) is very similar to that of the base, but this is supported on a table that is moved in the x-axis by a fixed nut below table. You see it at the last picture.
Step 4: Z axis
And finally the z-axis, similarly fact that the other two axes and carries a support for a milling or engraving machine. To test I used a screwdriver to move the axis. :)
Step 5: Assembling all of axes
The final assembly is simple with some screws. I have not used glue to replace parts if broken.
Step 6: Electronic connections
The connectiosn are simple. You need to use one driver for each motor. Each driver need power supply to work. I use a 24V 15A power supply. I select in the drivers my motors amperage. The A+, A-, B+, B- correspond with each of two coils of the motors and his poles. CLK+ (Clock) connects with the step pin on Arduino, CW+ (Clock Wise) connects to direction pin, CLK- and CW- connects to GND pin. EN+ and EN- not need to connect.
In the link below are the Arduino pin diagram of GRBL and some descriptions.
https://github.com/grbl/grbl/wiki/Connecting-Grbl
Step 7: Load and configuration of GRBL on Arduino Uno R3
I see this video to load GRBL on Arduino Uno R3. In the description of this are the links to the programs and files of GRBL. Is very simple. With XLoader load the GRBL code (grbl_v0_8c_atmega328p_16mhz_9600. hex) on your arduino, then open GCodeSender to conect your Arduino to your pc and it's ready to use.
This video explains how to configure GRBL according your stepper motors.
Step 8: Finish
You can use any CAD program to design your projects and CAM programs to machining the GCode for different needs work. I use MasterCam X7 that is CAD and CAM program.
And this is the final result and I hope you like it.
Thanks so much for watch this instructable and enjoy!
<p>Hi - great project!</p><p>Could you send plans and measurements, etc.?</p><p>My email is search1510@yahoo.com</p>
<p>Hi, where did you find nylon linear bearings? I'm searching on Aliexpress or banggood site but I can't find it. Could you post a link where i can find it, please? 10x in advace.</p>
<p>thanks a lot to everybody</p>
Lookup IGUS.COM download the application manual and pick your stuff.
<p>The nylon bearings I did not buy them for Internet. They were made-to-measure in a company of my city. Provided that it is a small company and does not have web page, say to me the measures and the quantity and I can ask the price.</p>
<p>check at igus.com</p>
<p> i am robo by vinoth kumar</p>
<p>I have a 1up 3d printer that the company just can't get it together with the wiring, so this is the next thing for the parts I have, kick ass project!!!</p>
<p>can you give me steel tube size</p><p>prabharsh@gmail.com</p>
<p>can u give me stl parts of this build please i wonna build the same !! send me in my email : xana@live.com; thanks </p>
<p>Hola excelente trabajo!.. te queria consultar si tenes los planos o algo para sacar las partes de madera. gracias!</p>
<p>Hi i was just curoius if you cold attach a high speed motor and mini chuck to actually have a CNC machine</p>
<p>Yes, you can connect whatever you want, either a high-speed motor or a laser.</p>
hi can i use nema 17 unipolar 6 wire?
<p>You can, but you need to identify the two center tap wires and leave them disconnected. Start by using a meter to measure the resistance between all the wire pairs. You'll see that there are 2 sets of 3 wires that are connected. </p><p>Now for each set of 3 wires, you'll see one pair that has 1/2 the resistance. Those are the wires that you connect to the motor driver. The pair that has higher resistance will be the center tap wires, just leave them disconnected. That way you can use a unipolar driver to drive a bipolar motor.</p>
<p>Hello,</p><p>I honestly could not tell because I used 4 wire bipolar motors.</p>
Hola muy interante tu proyecto me gustaria hacer una cnc asi pero para trabajar acero me puedes dar un consejo? gracias
<p>Muchas gracias!</p><p>Pues el tema del trabajo en metal se me escapa un poco de las manos, aunque si es verdad que me gustar&iacute;a probar con aluminio, ya que solo he trabajado con madera, pero con una estructura as&iacute; de robusta y con las fresas espec&iacute;fias para cada tipo de material no creo que tengas problema alguno.</p><p><u>Un saludo!</u></p>
<p>Very interesting post. Thank you for taking the time to upload this. </p>
<p>Thanks so much!!</p>
Thank you for such a nice comment. It is appreciated.<br><br>The very best.
Very cool project but expensive..
<p>Thanks!</p><p>It may be, but considering a CNC of this size can cost mounted about 1000 &euro;, I think it's not so expensive.</p>
<p>Como estas Johnnie yo estoy recien iniciandome en esto, soy ingeniero mecanico asi que estoy mas flojo con la parte de control. Tendras el codigo para arduino asi lo tomo como referencia&iquest;</p>
<p>Muy bien Gracias!</p><p>Te dejo el enlace al c&oacute;digo que met&iacute; en el arduino, pero debes hacerlo como explica en el primer v&iacute;deo del paso 7 ya que no es un c&oacute;digo .ino, si no que es un c&oacute;digo hexadecimal que solo podr&aacute;s cargar con XLoader.</p><p>https://raw.githubusercontent.com/grbl/grbl-builds/master/builds/grbl_v0_8c_atmega328p_16mhz_9600.hex</p>
<p>buenas, estoy buscando realizar un proyecto similar para mi carrera de dise&ntilde;o, y me gustaria si pudieras compartir info que usaste para desarrollar tu cnc, me parecio un dise&ntilde;o muy bueno y lo otro , como se podria conectar una dremel a este dise&ntilde;o y es necesario controlarlo? un modulo para corte laser se podria instalar tmb?</p>
<p>Buenas, todo lo que he utilizado para desarrollar el proyecto est&aacute; explicado en los pasos anteriores. En estos momentos yo tengo montada una fresadora, pero de igual modo puedes montarle una dremel, la cual no es necesario controlar. De igual modo, si quisieses controlar la activaci&oacute;n y desactivaci&oacute;n de la dremel al iniciar y terminar los trabajos, se podr&iacute;a hacer conectando la salida del arduino &quot;spindle enable&quot; a un rel&eacute;, tambi&eacute;n conectado a la dremel, el cual hace de interruptor para &eacute;sta. Tambi&eacute;n se puede poner un m&oacute;dulo de corte laser, ya que ir&iacute;a conectado del mismo modo que te acabo de explicar.</p><p>Espero que te sea de ayuda.</p><p>Un saludo.</p>
This is fantastic. Where can I get the draft and the necessary materials?
<p>I'm sorry but I don't have the draft</p>
<p>Thanks!</p><p>You can get the necessary materials at hardware stores and electronics stores.</p>
<p>Hola, excelente aporte, un dise&ntilde;o hermoso. Quiero hacer mi propia CNC y la tuya me sirve muchisimo para comenzar. tiene el area adecuada pues la que queiro hacer es un prototipo para futuros proyectos y solo voy a fresar madera, acrilico y superficies similares. Me gustar&iacute;a si es posible un par de preguntas:</p><p>1. Que medidas usaste para tu dise&ntilde;o? Puedo usar MDF o Triplex?</p><p>2. Solo tengo 3 motores Nema 17. El presupuesto no es muy grande. Se puede hacer? Se utiliza el mismo driver? </p><p>3. Es posible que nos coloques la programacion del Arduino y el programa con el que enlazaste el dise&ntilde;o?</p><p>Un abrazo inmenso y muchas gracias.</p>
<p>Much&iacute;simas gracias!</p><p>Ante todo perd&oacute;n por la tardanza de la respuesta.</p><p>1. Las medidas son las que aparecen en la imagen que te dejo m&aacute;s abajo, las cuales son aproximadas, ya que todo lo fuimos haciendo sobre la marcha y sin apuntar ning&uacute;n tipo de medidas y sinceramente no he tenido tiempo de medir todo con exactitud. Yo us&eacute; Triplay porque es bastante ligero y muy resistente a las deformaciones. Puedes usar igualmente MDF, pero creo que ser&iacute;a demasiado pesada la m&aacute;quina.</p><p>2. No hay problema en montar esos NEMA 17, siempre y cuando tengas en cuenta, por un lado la fuerza que son capaces de ejercer, y por otro lado la corriente que necesitan para funcionar. Si la corriente que necesiten es menor de 2A te recomiendo usar unos drivers POLOLU (A4988), ya que llegan a suministrar 2A como m&aacute;ximo y son bastante m&aacute;s baratos que los TB6560, los cuales proporcionan un m&aacute;ximo de 3A y son los que yo tuve que usar, ya que mis motores funcionaban 2,6A.</p><p>3. En cuanto a la programaci&oacute;n del Arduino, lo tienes todo en el paso 7 del Instructable, incluido v&iacute;deo de un muchacho que lo explica paso a paso.</p><p>Sin m&aacute;s, un saludo y espero que te sean de ayuda mis respuestas. Ponte en contacto de nuevo conmigo si te surge alguna duda e intentar&eacute; contestarte lo antes posible.</p>
<p>Hola, Much&iacute;simas gracias por tu respuesta. No te digo la emoci&oacute;n por tu respuesta. He comenzado inmediatamente a construir la CNC con tu aporte. Disculpa si te molesto pero me gustaria saber las dimensiones de las varillas de acero y las varillas roscadas asi como las de los rodamientos. Una cosa mas, el cajoncito que hay detras del taladro o base para el, que dimensiones tiene? ahi va la electronica? o se construye un cajon debajo para contenerla?. Te haremos caso y ya pedimos los Nema 17 y los controladores que sugeriste. Solo nos queda duda con la parte mecanica pero espero poder aclararlo pronto. De nuevo mil gracias y nos has hecho muy felices con tu colaboraci&oacute;n. Desde Colombia un abrazo inmenso.</p>
<p>Muchas gracias a ti y no te preocupes, no es molestia, solo que ahora estoy de ex&aacute;menes finales y ando poco por el portal. En cuanto al tema de medidas, ahora mismo no te puedo decir exacto, ya que estudio fuera de mi ciudad, no tengo la CNC conmigo y tendr&iacute;a que medirlas, solo recuerdo que las varillas lisas son de 20mm de radio las de los ejes X e Y, y las del eje Z son de 16mm de radio, por lo tanto los rodamientos han de tener los diametros internos del mismo radio que las varillas, 20 y 16 mm respectivamente, y en cuanto a las roscadas todas son de 14mm de radio. La electr&oacute;nica, si te fijas bien en las fotos que hay en el paso 6, ver&aacute;s que la tengo en un cajoncito a parte.</p><p>Espero que te sea de ayuda.</p><p>Un abrazo desde Espa&ntilde;a.</p>
<p>Muchas gracias por tu respuesta. Las varillas lisas que se consiguen en mi pais son de 8mm, 10mm y 5/16, el largo minimo es 1m, pero se consguen de la medida que desees. Las roscadas vienen de 8mm x 1m o de 8mm x 500mm. Una pregunta: dimensiones de estas varillas. Bueno espero que te vaya muy bien en los finales. Esperare a ver si luego me puedes enviar la longitud de las varillas. Un abrazo y cuidate mucho.</p>
<p>Gracias!</p><p>El motivo de que haya usado varillas lisas de 20mm para los ejes X e Y es porque as&iacute; se evita que &eacute;stas se puedan combar y luego haya error de precisi&oacute;n en el eje Z. En cuanto a las varillas rosacadas ser&iacute;a conveniente m&iacute;nimo de 10mm por eso de la robustez de la estructura. Las varillas rosacadas las compr&eacute; tambi&eacute;n de 1m y luego las cort&eacute; al largo que necesitaba, pero las lisas si es verdad que me las hicieron en una empresa y me las cobraron al peso. La longitud de las varillas no te las podr&eacute; decir m&iacute;nimo hasta dentro de 2 semanas.</p><p>Un saludo!</p>
<p>Muchas gracias por contestar. Lo que sucede es que un amigo mecanico que me va cortar las varillas estaba confundido con el diametro de las varillas y le parecia que el radio de 20mm era excesivo para el tama&ntilde;o. Pero lo has aclarado perfectamente. Por supuesto esperaremos a ver que mas detalles nos puedes brindar. Mientras cortaremos y tendremos la estructura lista para cuando podamos tener las medidas. La parte electronica tambien esta en proceso. Te estaremos informando. Te envio un abrazo y mucha suerte.</p>
<p>could i use the nema 23 bipolar 2.8A 269ozin step motor with this project?</p>
<p>Hola.</p><p>Yo tengo hecha una cnc no tan bonita pero funcional.</p><p>Llevo varios d&iacute;as atascado con el mastercam y con el cnc control. Cuando intento hacer medias circunferencias(o circulos), me hace un arco de 90 grados y luego una l&iacute;nea recta hasta el punto final. No doy con la formula. Cualquier pista sera de ayuda.</p><p>Un saludo.</p>
<p>Buenas!</p><p>Viendo las im&aacute;genes que me adjuntas, dir&iacute;a que el fallo ha de estar en la interpretaci&oacute;n que hace el CNC Control del c&oacute;digo que sacas de MasterCAM, porque en la imagen del MasterCAM parece todo correcto. A parte, nuca he usado el CNC Control y de ser el fallo de &eacute;ste, no sabr&iacute;a decirte cual el la soluci&oacute;n. Yo uso el UniversalGCodeSender, y hasta el momento no he tenido ning&uacute;n problema. Prueba con &eacute;ste y si el fallo persiste, tiene que ser algo del c&oacute;digo G que saca MasterCAM que tenga fallo.</p><p>Un saludo!</p>
<p>Hi Sir, Very nice and very elegant design, i am verymuch inspired by this, </p><p>may i know what is the maximum build area or work area of your cnc</p>
<p>Thanks so much!</p><p>The approximate area of work are about 37 x 48 cm.</p>
Thanks for the reply Sir, I am very much impressed by ur design, I am an asst.prof in information sc. dept. but I am trying to build my own cnc. i have scavenged some of materials from old printers. Unfortunately, i have nobody to guide me even profs. from dept Mech. if u don't mind can I expect ur help through mail - dreamcnc.rvsr@gmail.com, plz. This is my dream project. waiting for ur reply
<p>Thanks so much!</p><p>What you need?</p>
<p>can you modify it? the work area, make it bigger?</p>
<p>Yes, you can do the area as big as you want, but if the area is too big I recomend you to make it metallic.</p>
<p>What software would you use with this?</p>
<p>To machine parts I use MasterCam X7 and, to send the code to the Arduino, I use UniversalGCodeSender.</p>
About This Instructable
422,942views
2,952favorites
License:
More by JohnnieT:Arduino CNC
Add instructable to:
