loading
Step 7: The code is the glue
I have included the code which hopefully read with the following notes should make it self explanatory.
I used the latest Arduino IDE 1.0 which I must say has been brilliant especially as you can now programme using the ISP programmer and not have to worry about USB dongles or circuitry.  One thing I would say you still need to burn the boot loader onto your blank ATmega328 chip otherwise debugging becomes a bit of a challenge as the Arduino environment hasn't been set up properly!!!
The code I have compiled is 8,346 bytes in size so you can use the ATmega168 chip if you have a few kicking around.
Libraries:
Arduino.h - the standard and very large library
DS1302.h - Real time clock library
LCD4Bit_mod.h - Library supplied to support the LCD/Keyboard - very similar to the Standard library
OneWire.h - Provides communication to the temperature probe
Pinout Allocation and Global Variables:
This is where you need to set your own sunset and sunrise depending on your location.  We have summer savings here in the UK but I decided to keep my system on GMT which means when I look at the clock in the summer saving time period it is an hour behind so the sunset and sunrise times need to be set accordingly.
Setup()
  1. Sets the pinouts for the motor
  2. Sets the display back light which is switched off on reset.
  3. The current MotorState is set to STOP
  4. The top line of the display is initialised with the status headings.
  5. At this point we check the temperature to initialise the min/min max settings and display it.
In the code you will notice a commented out routine 'set_time()' to set the RTC.  This should be uncommented for the first time programming so the clock can be set.  Comment it out and reprogramme the ATmega328 again this way if the board is reset or further changes to the code are made the RTC always has the correct time.
You need to experiment  on setting the RTC in sync with the laptop time.  I discovered on a Mac environment you need to allow 40 seconds for compiling and uploading to make sure the times where exactly synced.
Loop()
  1. Print the current time
  2. Pause for 0.5 second so the display can be read.
  3. Print the bedtime which is in total minutes with the '^' symbol in front of it.
  4. Print the minimum temperature with the 'v' symbol in front of it.
  5. Pause for 0.5 second so the display can be read.
  6. Print the wake time which is in total minutes with the 'v' symbol in front of it.
  7. Print the maximum temperature with the '^' symbol in front of it.
  8. Pause for 0.5 second so the display can be read.
  9. Print the current time
  10. Check the door activation button (display on/off, close door or open door manually)
  11. Change the Motor State according to activation button
  12. Check to see if it is wake time if so set Motor State to DoorUp
  13. Check to see if it is bed time if so set Motor State to DoorDown
  14. While the State Motor isn't 'Stop' call door_change to either close the door or open it and display status on screen
I would suggest you familiarise yourself with the code and hopefully you can understand it enough to make your own modifications, i.e. no temp probe but a LDR instead.
As you can see from the code I have created a state motor variable which ensures actions are completed before the main loop code goes back on itself.
<p>NO criticism. </p><p>But why do you need to to close the door anyway. Ive been keeping 20 hens and 1 rooster for 9 months in an 8' X 8' X 8' enclosure with a man door on one side and and a 16&quot; X 16&quot; opening for chicken access on the other. Oh yeah, there is an 8' X 8' skylight for a roof. The chickens are free to come and go as they please and roam around. </p><p>I had a fenced in area but the goats destroyed the fence climbing in so they are no longer fenced. When it gets dark they go in and roost and when the sun comes up they go out and 'play'. Only problem with the skylight is the full moon - rooster crows at 3am., sigh.</p>
<p>I'm curious where you live that you've managed to keep chickens alive for 9 months with an open coop and run. I don't live near a nature reserve or in the wilderness. I'm in the suburbs of a large metropolitan area. We have coyote, fox, bobcat, raccoons, opossum, mink and weasels - not to mention hawks and owls. On almost every occasion I haven't made it home by dusk, I lose birds - sometimes whole flocks. Until I closed off every opening larger than 1/2&quot;, mink started attacking. In 5 nights I lost 5 flocks to mink. No meat eaten, just killed.</p><p>When it comes to raccoons, in retrospect I would have saved money by buying a premade auto coop door for every building. And saved a lot of rare birds in the process.</p><p>As for Robot-Chicken, I really appreciate the detailed sketches of the latching mechanism. </p>
Typo, should have been 6 months. <br>I live on an island in the Pacific Northwest in a rural but becoming a suburbanized area with people buying 5-10 acre parcels around me and putting up fences to keep their animals in and deer out, sigh.<br>I acquired 20 chickens and a rooster late Oct., early Nov. Lost three then acquired another 3. Now I'm down to 14/1. I'm assuming the losses were due to Eagles as there is no shortage of them around here. <br>They would exit the roost at dawn and be back in bed by 7pm. <br>The deer and coons roamed all over the place 20 years ago but I haven't seen either for years, again sigh. There was a neighborhood dog that took out 4 of the ducks I was trying to raise and he hauled them off and I never found the bodies. With the chickens I've lost there was always a pile of feathers and if I found it early there was an eviscerated body otherwise just wings, head and feet. <br>On occasion I hear a coyote and have seen two. We have hawks, HUGE 'horned owls' and Eagles. It's total woods where I live but there is a clear cut area next door. <br>I'm experimenting with hatching, as of this morning I have three out of 17 eggs where the little buggers are escaping from their shells. Should be more later on in the day and over the next week as the incubator was added to over the course of a week. Started with 18 but one didn't candle after 10 days so I culled it. Brown, white and 'green' eggs - that's all I know about the chickens. <br>Turned an old fridge into a brooder for them to run around in until they are big enough to turn out into the 'wild'. <br>Scotty
None taken. <br><br>Our coup is next to a nature reserve full of foxes which have in the past devastated the coop and my little ladies!! We have also put a fence around as a first line of protection.<br><br>The other reason which you eluded to is we can keep our little darlings in the dark and release them at a more sociable time for them to cluck and forage. Having hens clucking at 4 in the morning wouldn't make me popular with my neighbours who live less than 25 yards from us in either direction.
One day I was up early when a fox came over and started inspecting our chicken coop. All the chickens where inside and the door was closed so no chicken breakfast for the fox. Then Another time I had a coop that was left open all the time with a wire fence around it. One day I went out to find the a hole in the wire fence with 7 dead chickens. From that moment on the chickens got closed up at night. It is better to be safe then sorry.
<p>I'll see you but won't raise. Been having phone and internet problems so phone guy was here last Friday morning and we were outside fiddling with the junction box. Bald eagle with at least a six foot wing span came down 20' away in front of my cab over motor home trying to get one of the chickens that had run underneath. Hank ran around one side and I, the other. Eagle left 'empty handed' this time. </p>
Ah ha, neighbors. Good incentive for auto door. My closest neighbor is a couple hundred yards away so, no one to bother and were probly not on good terms anyway.
I've automated our coop as well using a Raspberry Pi. The system controls heat, a/c, open and close of the door, turns interior light off and on, video camera inside just for fun mostly, and texts/emails me when door opens and closes, controls auto feeder and keeps my wife and I happy! <br>The biggest suggestion I can make to you is to use an electric linear actuator to open and close the door. This precludes the need for any locking mechanism. This is the 16&quot; actuator I use: http://pages.ebay.com/link/?nav=item.view&amp;id=361075336287&amp;alt=web
<p>Following up...3 years later...We started with 12 peeps, sold 4, 4 gone to predation (the risk of letting them run free). Arduino based Uno R3 running continuously all 3 years!</p><p>Now returned to door design for the next batch next spring. I modified some code from Roger Reed. My controller takes care of lighting, power ventilation in summer, shared with water heater for winter. (inverted flower pot with light inside). RTC will remain as a system clock. It also has a separate egg box light that flashes should the egg box be left open. One indoor temp sensor (no display :( (yet!)), but still actively in control! </p><p>Hope to add 2 more temp sensors and an indoor remote controller over rf this year...parts here, time not. The implementation of all features desired will require a mega 2560, and I am considering off loading door control to a subsystem for modularity. Light is currently relay controlled AC CFL, and will be replaced with LED pwm, filtered to remove flicker, and fading up/down to improv asthetics for the girls. Door will have a servo lock as I did not like the mechanical solution for the added weight. Locking will be verified by status LED, as will door position.</p><p>An addition I really like (for anyone considering a smlilar project) is an LED flashing a heartbeat. It is visible from the house, dims at night based on a light sensor, and provides reassurance that all is well, without being over bearing at night. It provided great feedback during the -20F temps last winter to know the system was surving and operating normally! (I was delighted the UNO clone kept on chugging through the 2+ weeks of sub 0 temps!)</p><p>Many thanks for your continued inspiration! Where is V2.0?</p><p>Cheers,</p><p>-fab</p>
<p>What an excellent instructable! When I first looked and saw the wooden door and the banged on latches, and rather odd looking elevator mechanism. I was a bit skeptical. But, you have thoroughly impressed me with your very well thought out design and the code is absolutely fabulous. Are you sure you want to keep raisng chickens with your time or go into product design and code development? (kidding...of course you seem totally happy doing what you do). I just wanted to thank you for a delighful experience in learning and say you have helped me with my little project quite nicely. I've gotten some very nice new ideas (for me) from your project. Thank you.</p><p>JB from Las Vegas, Nevada</p>
Many thanks JB for the comments<br><br>I originally was a modem product introduction engineer when I first left University and also a digital signal processor coder. So I kind of gone full circle! I am also a master class lecturer for The Royal Institution (of Faraday fame) so hopefully encouraging kids to enjoy building and programming Arduinos. A few of your countrymen have also built the coop controller adding their tweaks.
<p>Is there a way to make a servo with a timer used to pull a door open at <br>sunrise and let it slide down at sunset automatically everyday? It's for <br> a chicken coop. That's a good idea for sunrise and sunset, but what if I want a timer so <br> I can adjust the opening and closing at times I choose? Letting the <br>door open too early is not good because my neighbors are asleep and the <br>chickens will wake them up. I would ideally like to adjust the time of <br>opening 1-2 hours after sunset.</p>
<p>It would need to be a large servo as the door is quite heavy. </p><p>I set my time to open the door for around 6.30 in the summer so as to give my neighbours a lay-in but you need to make sure your coop is sealed from the light. You can adjust the time within the program or the menu</p>
<p>It amazes me what people can do. I too am a small time chicken rancher and have also wanted a way to open and close the coop automatically. ALso, there is a need to automate watering. Unfortunately, I know nothing about Arduino.<br><br>My rough concept is to use water trickling into an empty bucket on a lever (with the door on the other end of the lever) as a weight to eventually, gradually, open the door, which would ultimately tip the bucket into a water trough for the chickens to drink and close the door. Then the bucket would spring back up, right itself and begin filling again. Each fill/dump-open-close cycle would need to take about 12 hours.<br><br>I have not prototyped it yet. I do prefer simple machines that don't require a computer to operate. But, that's just me.</p>
I am also interested in Automatas and you idea would be brilliant to see in operation all powered by water. Outside temp may be an issue hear as it went below -10oC here in the last month
<p>Hi love the build. Do you think it could be done with a photo cell to trigger open and close instead of the timer ? That would be an ideal setup in my opinion.</p>
<p>Hi may i know all the components used in this project?</p>
Great instructable! I'm just finishing my coop and will be giving this door and controller design a go. <br> <br>With the experience you've gained, which arduino board and shield(s) would you suggest I use? I'm not very good at soldering so I'll be looking at constructed components when available. <br> <br>Thanks!
Hi I am probably about a month away from publishing ver2 which uses a rotary switch and a 4 x 20 LED screen. All the components are modules except for the Arduino board which is a modified prototype board - which you could use an Uno v3 if you don't fancy any soldering. I have attached a some of images to show you the new hardware layout and screen. As such I didn't use shields just discrete modules with interconnect wires which you can do with the ver1 design. <br> <br>Any motor module that can deliver 2-3amps usually has an LM298n chip with the 2 channels linked together will do. There are some very cheap 1302 RTC modules with battery holder. I used a cheap 20x4 LCD in 4bit mode with the standard crystal LCD library. There are some shields to fit the UNO with integrated analogue keyboard and screen you can use. Hope that helps
<p>very good job .</p><p>your project let start me learning arduino.</p><p>we wait for v2 </p><p>thanks </p>
Thanks for that, I'll look forward to seeing your v2!
Wow. I just love this idea! Great execution.
So how much would you charge for one to be built and sent to the US??
Honoured that you would buy it from me but unfortunately I just don't have the time. There are at least 3 folks in the US who have built it so perhaps they might be able to help you without putting them under too much pressure!! I suspect it will be a lot cheaper as well - happy persuading!
Love it!! But how does the door stay open, is the motor engergised all the time the door is open? if so why the top micro switch?
Hi glad you like it. The planetary gearbox is stiff enough to keep it open once the top limiter switch is triggered. So it only needs 2 amps of battery juice for about 1 second - very efficient
That lock is really smart! And well made 'ible! <br> <br>If you think about it and add a long spring to replace gravity, you can use that idea even in horizontal direction for other projects...
Well I can't take credit for the design - only the reverse engineering of it. I like the idea of the spring. I have another follower who is in the process of making his own. Really looking forward to seeing how he has improved the design - I think he is using draw runners for a smoother action.
i built a 10x10 shed for my two geese. i really like your plans, i am going to use them with some modification.. it will have a steel plated door because i live in the middle of the woods and foxes and other such animals are common. to heat my coop i have a forced air propane heater. the unit is also a a/c so in the summer the vents are blowing nice cool air. all the walls and doors are insulated, do you have a suggestion for insulating the automated door? <br>as a final comment i would like to thank you for caring for the ex-battery chickens. in a unrealted way: one of my geese broke is femer (which is inside its body, not accessiable by topical cast) so i went to the only place i know crazy enough to do sugery of a pet goose (cornell universty vet hospital) it cost me close to $2000 in medical bills, and a entire summer vacation inside caring for it.
Hello R C, <br> <br>I need first of all to congratulate you for this great design and implementation! <br> <br>I've been planning for some time to implement for my own coop an automatic door but with the use of an LDR (we have no lights where the coop is), so now that I found this I will certainly start building it! <br> <br>As I have almost no knowledge of electronics, just good soldering skills and good &quot;follow instructions&quot; skills I have probably a couple of rather &quot;dumb&quot; questions (English is not my native language so you may have already answered this in your instructable and I just didn't get it!). <br> <br>Is the output of the trickle charger connected on the power input of the H-Bridge? Is the battery connected in the same power input of the H-Bridge? <br> <br>Does everything work with the main power supply and charge the battery at the same time and when the main power fails the battery kicks in? <br> <br>Thank you very much and once again thumbs up!!! <br> <br>Regards, <br> <br>Apostolos.
Hi R C, <br> <br>Firstly, a great instructable - I'll definately be basing my set up o it in the spring. <br> <br>One suggestion That would be good is some form of timed switch to trigger an LED light in the coop that would increase the light-hours - to ensure decent egg production in the darker winter months. NOT on a battery level!!! But I've read it can be better for the chickens to have a minimum of about 11hours light a day. <br> <br>I'm not an electronic/programming buff, so there's every chance it may not be possible, but would be good if it was. <br> <br>I look forward to version 2. Any ideas when it will be ready? <br> <br>Regards, <br> <br>Matt. <br>
Firstly many thanks to those who have given me some great feedback and have built their own chicken coop controller. <br> <br>I am currently working on version 2 which has: <br>- a visual indication the door has closed successfully, <br>- ability to turn on a low power heat lamp when the temperature drops too low <br>- Improved display and time setting <br>- those who would like to keep the lights on for a little while to keep their egg production up. Chickens normally needs10 hours of light to produce a single egg <br> <br>It is likely to be a couple of months so watch this space. Further improvements for my fine feathered friends serious or funny are greatly welcomed - R-C
Thank you for a great Instructable! The door instructions and measurements really helped me build my own. <br> <br>I decided to use a remote control to open/close the door from the house. This way I could make sure no predators were around first. If you wish check out the short video - http://youtu.be/UXNF4LRmzik <br> <br>Again, thank you for a great Instructable. :)
Also Chicken lover. Nice project. Very clever all round. Three thumbs up!!!
Nice job, !! &lt;- two thumbs up.<br><br>From that last photo, one improvement that the hens would like is to add a heated towel rail for their roost ;)
Don't for get the heated floors too :) A 30+ meters of insulated wire and the 12v power source and these guys will be loving it.
That is so funny - it is almost true. The reason for the temp measurement was to turn on an infra red lamp to warm them up if it gets too cold!!<br><br>Version 3.0 will be the automated turn the straw down before they go to bed!!
&quot; I wouldn't trigger the door opening or closing on light detection alone as it could be volatile to poor weather or the garden flood light as the fox enters our garden!&quot;<br><br>I was thinking that you could skip the arduino and go just with a photodiode and a few mosfets, but that is a good point. The fox walks near the security light, the light goes on, the door opens, and the fox gets a snack. <br><br>All around great instructable. Lots of good details.. <br><br>Perhaps there is a photodiode out there that senses a wave of light that isn't emiited by the flood light but is still emitted on days with alot of overcast, maybe UVB light around 350nm. Then a temp sensor to control the heat lamp.
Well done Robot-Chicken! Nice to see you giving those hens a better life. And I will be taking some aspects of your door design!
Feel free - using any aspect of the design would be the greatest form of recognition - have fun with it
chickens create tons of dander (skin and feather dust) that coats everything, make sure all electronics and working parts are protected. Otherwise your door is going to gum up in short order. Also wood swells when damp, which means in the high humidity of summer, rainy springs and falls, depending on where you live, the door may jam. Especially when you mix the water with the chicken dander! Make sure there is plenty of free space in the slide mechanism. And, either build a sufficient overhang to keep the door completely dry, and/or better, yet prime and paint all of your wood pieces.<br><br>Roosters (plural) make a heck of a lot of noise. They have to compete with each other. A rooster (singular) makes less noise then a bunch of hens.<br><br>I've been raising free range (no fencing), chickens in a wooded area (and in the past in an open area) for more then 30 years and only one thing works to keep chicken predators at bay - a good farm type dog.
Your are right I had to create a wooden defence mechanism against the dreaded poop. Every week the door gets a good inspection to make sure everything is in order and the wood is treated so hopefully it will last a while but know doubt will need replacing. I had the manual door fitted for 6 months during autumn and winter and it seemed to fair well.
Your &quot;before&quot; and &quot;after' pictures of the hen says it all. Great job with the rescue. It's wonderful to see how they can recover from that experience.<br><br>The coop looks great too. I love it, but I am very lazy &mdash;<br><br>Alternatively, a very, very simple solution is what I've been experimenting with this past year &ndash; totally free range-ing my chickens (small flock with two very big and very mean roosters, that is essential to the plan). Anyway, mine have branches for roosting high (about 5') in a run-in shed, and several modes of escape in the event of four legged predators. It's working so far. Hawks are another thing though, but that's a daylight problem.<br><br>The beauty of 24/7 free range for me is of course not having to get up early. <br><br>There isn't a chicken enclosure made that some predator can't get in, alas, and the carnage when they do is heartbreaking.
I agree total free range is clearly best route - I live in a town so Rosters are a no-no hence the small size garden and coop - Still worth it though just for the fresh eggs
Well---it's not necessarily &quot;best&quot; the way I'm doing things. There are a ton of variables to each persons setup. I live on and surrounded by mostly open farmland, so while we do have predators, maybe not as many as someone in a wooded area. I may have just found what works well HERE, but most people go the route of shutting them in at night, and that's probably safest in 90% of the cases.<br><br>Roosters make a hellava racket :)
Hi,<br><br>as I still did not used arduino could you please consider this idea :<br>http://www.treehugger.com/gadgets/diy-solar-powered-bird-house-tweets-when-birds-arrive.html<br><br>to allow solar power battery charging / or directly to power DC motor (may be change the current motor you used due to the voltage).<br><br>I ask you this because my backyard is too steep I though to use solar powering with those cheap small photovoltaic panels :<br>http://energybible.com/solar_energy/outdoor_solar_lighting.html<br><br>Or may be given the perfect photovoltaic solar panel that must be used to get the arduino power.<br><br>Sincerely thanks for your help and have a nice day,<br><br>Miguipda ;-)
Hi Miguipda<br><br>I very much like the tree hugger link. I am seriously considering reviewing the design so I can light-weight components and reduce the Arduino power consumption so that everything can run off rechargeable batteries and solar power. I think I will need to invest in a high quality motor instead of being thrifty with my &pound;5 motor assembly
I'm wondering if the arduino is required at all for a simple version that merely opens the door at sunrise and drops it after sunset. A solar panel, a motor and gearbox, a photoresistor, big capacitors, and some glue components are all you'd need. But the arduino certainly allows for adding on functionality like monitoring temperature or even detecting a fox or thief disturbance should one want to so I'm not saying that it doesn't have its coolness too. The minimalist in me just went down the other path.
I think you are right you can get away with something simple. The only issue I have with a photo resistor are false readings opening the door in the middle of the night. In my garden we have a PIR light which comes on even when a fox is in the garden. So I didn't really want to present Mr Fox with an opening door to a late evening lunch!! In a big open space without spot lights you are spot on - pardon the pun.<br><br>However if you stripped the design down to the bare safety levels for my little ladies then everything thing you said plus a simple pwm arduino board would surfice.
About This Instructable
121,781views
440favorites
License:
Bio: I am consultant who spends his spare time dreaming up stuff and reading other people's great ideas. I have a growing family and a ... More »
More by Robot-Chicken:Chicken Coop Controller v4 Software Update Chicken Coop Controller v2 Software Update Arduino Chicken Coop Controller
Add instructable to:
