WHATS A RELAY?
a relay is a component that can be used to control large amounts of voltage or current with just a small voltage, it does this by using that small voltage (5 volts in our case) to create a magnetic feild that will pull a switch type object to connect the larger current (120 volts in our case). Image 2 is a diagram on how a relay works
Remove these ads by
Signing UpStep 1Supplies
• 1x Protoshield/ breadboard
• 8x 5v DC relays »»» search.digikey.com/scripts/DkSearch/dksus.dll
• 8x 1N4004 diodes »»» search.digikey.com/scripts/DkSearch/dksus.dll
• 8x 2N2222 transistors »»» search.digikey.com/scripts/DkSearch/dksus.dll
• 8x 1K (Brown,Black,Red) ohm resistor (radio shack)• 1x double/single sided PCB (radioshack)
• 1x sharpie
• 16x nuts and bolts (discuss size later)
• 8x dead sets of lights (for there male plugs)
• 500 ft of 5 strand cable
• a set of connector things
• some wire and some other stuff that you should have
• a place to display your light show
• and a some what knowledge of making pcb's
LETS BEGIN SHALL WE
If not, do you have an ideas on how to easily dim the lights?
Beyond the arduino outputs, everything should be the same as dany's setup. Then your songs/light shows are only limited to your patience with the sequencer.
Unfortunately, like you, I am still in the production phase and don't have a finished product to show such as dany's. I am as far as running some test LEDs with the sequence on a bread board, so theoretically, I'll build the board with the relays and be good to go...
http://www.youtube.com/watch?v=bucQrRSpv7Y
I like your idea about the xbee and the climate controlled box. However, part of the deal in getting my wife on board with turning our house into a musical light show involved committing to a budget of practically $0, so I'm working with only components that I already have. But thanks for the tip about the temp of the arduino. I realized that my crawlspace door in the floor of my guest room closet is within a few feet from the nearest crawlspace vent to the front yard. I think I'll set up the whole operation in my climate controlled ;-) guest room, and run the cables beyond the relay through the crawlspace to the front yard.
I also plan on using an FM transmitter to play my music. A buddy that's helping me with some of the wiring work told me that the range of the common dashboard mp3 player transmitters can be boosted by simply soldering a longer wire to their antenna on the cb and coiling around a rod. I guess we'll see if that actually works or not.
Let me know if you can't find the vixen plug-in code for the arduino, and good luck to you too!
traces for the power source to the relays and connected them together with wire. Was there a reason you didn't connect the wire once and combine all the power in traces to the relays into one long trace? PCB overheat?
Could there be a mistake in your drawing? I know i may have messed up somewhere, but what is your opinion.
Thanks for your help!
thanks, sorry it took so long to get back to you.
BTW: to reduce confusion on wiring the 120 Volt side of this project the "ground" on your circuit plans is actually the "neutral" wire o the house. If it was actually wired to the earth ground, there could potentially be an electrical hazard. :(
