Step 5Bringing it all together
1) i used some wire from the dead lights to connect all the positives on the pcb (image 1)
2) get the crimp connectors and connect some onto the wires coming from the trees like (image 2) leave the white be for now
3) connect those wires to the pcb in the correct order
4) i took an old exstention cord and cut the cord off and connected one end to the 120v input on the pcb and the other to the 2 whites
5) lastly connect the arduino up to the pcb (image 3)
6) tape up those connection and store it somewhere safe
7) upload the Joy To The World code, and see if it works. if so GREAT!!!! if not, not good. if you cant figure out the problem post a comment and ill try my best at helping you.
Joy To The World code:
int tree1 = 6;
int tree2 = 7;
int tree3 = 8;
int tree4 = 9;
int tree5 = 2;
int tree6 = 3;
int tree7 = 4;
int tree8 = 5;
int s = 150;
int ds = 225;
int e = 300;
int de = 450;
int q = 600;
int dq = 900;
int h = 1200;
int dh = 1800;
int start;
int end;
int time;
void setup()
pinMode(tree1, OUTPUT);
pinMode(tree2, OUTPUT);
pinMode(tree3, OUTPUT);
pinMode(tree4, OUTPUT);
pinMode(tree5, OUTPUT);
pinMode(tree6, OUTPUT);
pinMode(tree7, OUTPUT);
pinMode(tree8, OUTPUT);
digitalWrite(tree1,HIGH);
delay(1000);
digitalWrite(tree2,HIGH);
delay(1000);
digitalWrite(tree3,HIGH);
delay(1000);
digitalWrite(tree4,HIGH);
delay(1000);
digitalWrite(tree5,HIGH);
delay(1000);
digitalWrite(tree6,HIGH);
delay(1000);
digitalWrite(tree7,HIGH);
delay(1000);
digitalWrite(tree8,HIGH);
delay(1000);
digitalWrite(tree1,LOW);
digitalWrite(tree2,LOW);
digitalWrite(tree3,LOW);
digitalWrite(tree4,LOW);
digitalWrite(tree5,LOW);
digitalWrite(tree6,LOW);
digitalWrite(tree7,LOW);
digitalWrite(tree8,LOW);
Serial.begin(9600);
void loop()
start = millis();
digitalWrite(tree1, HIGH);
digitalWrite(tree8, HIGH);
delay(q);
digitalWrite(tree1, LOW);
digitalWrite(tree8, LOW);
digitalWrite(tree2, HIGH);
digitalWrite(tree7, HIGH);
delay(de);
digitalWrite(tree2, LOW);
digitalWrite(tree7, LOW);
digitalWrite(tree3, HIGH);
digitalWrite(tree6, HIGH);
delay(s);
digitalWrite(tree3, LOW);
digitalWrite(tree6, LOW);
digitalWrite(tree4, HIGH);
digitalWrite(tree5, HIGH);
delay(1050);
digitalWrite(tree4, LOW);
digitalWrite(tree5, LOW);
delay(s);
delay(q);
delay(q);
delay(dq);
delay(e);
delay(dq);
delay(e);
delay(dq);
delay(e);
delay(dq);
delay(e);
delay(e);
delay(e);
delay(e);
delay(e);
delay(de);
delay(s);
delay(e);
delay(e);
delay(e);
delay(e);
delay(e);
delay(e);
delay(de);
delay(s);
delay(e);
delay(e);
delay(e);
delay(e);
delay(e);
delay(75);
delay(75);
delay(dq);
delay(75);
delay(75);
delay(e);
delay(e);
delay(e);
delay(75);
delay(75);
delay(dq);
delay(75);
delay(75);
delay(e);
delay(q);
delay(e);
delay(de);
delay(s);
delay(e);
delay(e);
delay(q);
delay(q);
delay(h);
delay(20000);
end = millis();
time = end - start;
Serial.println(time);
BTW: to reduce confusion on wiring the 120 Volt side of this project the "ground" on your circuit plans is actually the "neutral" wire o the house. If it was actually wired to the earth ground, there could potentially be an electrical hazard. :(
