Arduino Color Mixer
Published
Introduction: Arduino Color Mixer
The purpose of this instructable is to show how to use an Arduino to create a color selector, for full color LEDs. The selector will have a gui interface which runs on a computer connected to the Arduino. The interface allows color selection by the use of red, green and blue slider gradients.
A video of the mixer controlling 3 LEDs is located here http://www.youtube.com/watch?v=9VBWqkRLqNs
what you'll need,
-breadboard
-full color LED's (as many as you want to use, I used 3)
-Arduino Uno
-breadboard, wire, ect..
Step 1: Connecting and Testing LEDs
the first thing to do is to connect 1 led to the breadboard, and the arduino. Each full color LED has 4 connections, it has a shared anode which is connected to one of the digital pins set as a +5V output. The LED also has a cathode for each color, red, green, and blue.
the easiest way to test the LEDs is to put them into the bread board, then set 1 of the arduinos digital pins to an output and the other to a input, the code to do this(using pins 11,and 12) is:
void setup() {
  pinMode(12,OUTPUT);
void loop() {
//this sets pin 12 to 0 volts so it allows a full voltage drop accross the LED
  digitalWrite(12,LOW);
//I used analogWrite here because applying the full 5 volts to the LED may damaged it.
// or you could just use resistors
  analogWrite(11,10);
Once you have figured out which cathode is which for each LED connect them in parallel, so that the +5V is shared by each Anode, and each red cathode for each LED is connected to pin 3, each green cathode is connected to pin 5, and each blue cathode is connected to pin 6. Once this is done the following code can be used to control the color of all of the LED simultaneously.
// with all values set to 255 the led will not light up, to test each color independantly just change the value
// of that color, the closer the value is to 0 the brighter that color will shine. Color mixing is achieved by having different values for red,
// green, or blue.
int rval = 255;
int gval = 255;
int bval = 255;
void setup() {
pinMode(12,OUTPUT);
void loop() {
digitalWrite(12,HIGH);
// Note you may need to re-order wich value goes to wich pin depending on how the LED is wired in.
analogwrite(3,rval);
analogwrite(5,gval);
analogwrite(6,bval);
Step 2: Color Mixer Software
Once You have all of your LEDs connected, the next step is to write the mixer software that runs on the computer.
the code is:
int rposx = 4;
int gposx = 4;
int bposx = 4;
int rval = 0;
int gval = 0;
int bval = 0;
int output = 0;
PFont fontA;
import processing.serial.*;
Serial port;
void setup() {
size(480,180);
background(170);
stroke(255);
fill(255);
rect(4,4,257,52);
rect(4,64,257,52);
rect(4,124,257,52);
fontA = createFont("Verdana",26);
textFont(fontA);
textAlign(CENTER);
text("Output Color", 360, 50);
// this will allow for serial port communication with the arduino
println("Available serial ports:");
println(Serial.list());
//selects the first port in the Serial.list() for use and speed of 9600
port = new Serial(this, Serial.list()[0],9600);
void draw() {
// this draws a circle wich displayed the mixed color that is being output to the Arduino
  fill(rval,gval,bval);
  ellipse(360,110,100,100);
// these draw the red, green, and blue gradient lines, as well as a verticle bar in each one to denote what amt of that color is
// being selected
    for (int i = 0; i<256; i++) {
    stroke(i,0,0);
    line(i+5,5,i+5,55);
  stroke(255);
  line(rposx,5,rposx,55);
    stroke(0,i,0);
    line(i+5,65,i+5,115);
  stroke(255);
  line(gposx,65,gposx,115);
    stroke(0,0,i);
    line(i+5,125,i+5,175);
  stroke(255);
  line(bposx,125,bposx,175);
void mouseDragged() {
 // this allows you to drag the bar in the gradient to select the color, by determining if the mouse is inside one of the gradient
// bars and which gradient bar you are in.
  if (mouseX < 260 && mouseX > 5 && mouseY > 5 && mouseY < 55) {
    rposx = mouseX;
    rval = rposx-5;
    float rout;
// for rout,gout,bout rather than sending out the 0-255 value for each i remapped the values to 0-85 for red,86-170 for green,
// and 171-255 for blue. this allowed me to only send a single serial port message from the computer to the arduino each time the
// color is changed
    rout = map(rval, 0, 255, 0, 85);
    int routp = int(rout);
      port.write(routp);
  if (mouseX < 260 && mouseX > 5 && mouseY > 65 && mouseY < 115) {
    gposx = mouseX;
    gval = mouseX-5;
    float gout;
    gout = map(gval, 0, 255, 86, 170);
    int goutp = int(gout);
    port.write(goutp);
  if (mouseX < 260 && mouseX > 5 && mouseY > 125 && mouseY < 175) {
    bposx = mouseX;
    bval = mouseX-5;
    float bout;
    bout = map(bval, 0, 255, 171, 255);
    int boutp = int(bout);
    port.write(boutp);
Step 3: Updating Arduino Code to Respond to Mixer
Once the Mixer Software is complete the final thing to do is to update the arduion sketch so that it can recieve the Serial commands from the computer. The code for this is:
int rval = 255;
int gval = 255;
int bval = 255;
int input;
void setup() {
//this allows for Serial communication with speed of 9600
  Serial.begin(9600);
  pinMode(12, OUTPUT);
// because of power needs i am using 2 +5V sources.
  pinMode(11, OUTPUT);
void loop() {
  digitalWrite(11,HIGH);
  analogWrite(3,rval);
  analogWrite(6,gval);
  analogWrite(5,bval);
// this detects weather or not there is any available incoming serial data.
  if (Serial.available()) {
    input = Serial.read();
//I then re-map the values from there 0-85,86-170,171-255 back to the corresponding 0-255 values.
    if (input > 0 && input < 86) {
      int rin = map(input, 0, 85, 0, 255);
// because we are connectiong the PWM port to the cathode, we need to change the values instead of 0-255 to 255-0
      rval = 255 - rin;
    if (input > 85 && input < 171) {
      int gin = map(input, 86, 170, 0, 255);
      gval = 255 - gin;
    if (input > 170) {
      int bin = map(input, 171, 255, 0, 255);
      bval = 255 - bin;
    • Clocks Contest
      Clocks Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    7 Discussions
    would it at all be possible to add a 4th "output slider"? i need it for a fan controller. im using this to control my pc's innards :D
    Well its been awhile since I've done this so I cant remember for sure, but looking at the arduino,there appears to be two PWM ports that were unused. I believe that either one of those could be used to provide variable adjustment for a fan. The code for a fan slider should be almost the same as for the RG&B sliders.
    my current code for the arduino is:
    int rval = 255;
    int gval = 255;
    int bval = 255;
    int fval = 255;
    int input;
    void setup() {
    Serial.begin(9600);
    void loop() {
    analogWrite(9,fval);
    //I then re-map the values from there 0-63,64-127,128-191,192-255 back to the corresponding 0-255 values.
    if (input > 0 && input < 64) {
    int rin = map(input, 1, 63, 0, 255);
    rval = 255 - rin;
    if (input > 63 && input < 127) {
    int gin = map(input, 64, 126, 0, 255);
    gval = 255 - gin;
    if (input > 126 && input < 189) {
    int bin = map(input, 127, 188, 0, 255);
    bval = 255 - bin;
    if (input > 188) {
    int fin = map(input, 189, 255, 0, 255);
    fval = 255 - fin;
    i am actually doing it now. i was almost done when my cat stepped on my power strip for my pc. i didnt save it :P anyway this is my first intro to arduino, thanks a ton for the base code :D
    Note: This code for the computer was written and runs on Processing. It is available free for download at processing.org . The coding language for processing is an open source one like for the arduino.
    As you've  guessed, i'm new to this:  and it says PFont does not name a type. please help!!!
    PFont is just used in to define the FontA variable as a font variable. You must then choosethe font that you want that variablebe to be. Is that any help? if not message me with the specifics of your problem and i will try to help you.
