Arduino Components Tester
1,606
7
12
Published
Introduction: Arduino Components Tester
About: student of ELECTRICAL ENGINEERING
Hello friends...!
You can make your own COMPONENT TESTER.
It can test....
Resisters
capacitors
Inductors
Every type of transistors(BJTs,MOSFETs,IGBTs..etc...)
And many things
It not just a component tester,but also it is a PWM generator........
Step 1: Components You Need.
List:-
Electronics.......
Arduino nano - 1
16*2 LCD - 1
9v Battery - 1
9v Battery cap - 1
PCBs
Resistors ---
680R - 3
470K - 3
1K - 1
variable resistor 10K - 1
some wires
push switch - 1
on/off switch - 1
equipments
soldering station or soldering iron,cutter etc...
Step 2: Diagram of Tester
R1 - 470K
R2 - 680R
R3 - 470K
R4 - 680R
R5 - 470K
R6 - 680R
R7 - 1K
RV1 - 10K
C1 - 100nF
Step 3: Connect Everything As Per Circuit Diagram
Codes you have to need is here
Step 4: Case for It
here i make case using PCBs
cut the pcb in size of main circuit
and cut some part of top pcb for LCD.
Assemble case using silver-copper wire...
simple.... ; )
Step 5: Some Test
Now it ready to be use.
Some tests you can show
Just connect the component to the probe and push the button.
If you want to use PWM function just long press the push button.
It's done.................
3 People Made This Project!
  • Oil Contest
    Oil Contest
  • Creative Misuse Contest
  • Clocks Contest
    Clocks Contest
12 Discussions
lol :(
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void setup()':
Components_tester:517: error: 'lcd_fixed_string' was not declared in this scope
Components_tester:544: error: 'LoadAdjust' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void loop()':
Components_tester:565: error: 'TestKey' was not declared in this scope
Components_tester:582: error: 'SetADCHiz' was not declared in this scope
Components_tester:583: error: 'lcd_clear' was not declared in this scope
Components_tester:585: error: 'lcd_fixed_string' was not declared in this scope
Components_tester:589: error: 'ReadU' was not declared in this scope
Components_tester:597: error: 'MainMenu' was not declared in this scope
Components_tester:601: error: 'AllProbesShorted' was not declared in this scope
Components_tester:607: error: 'lcd_line' was not declared in this scope
Components_tester:613: error: 'lcd_line' was not declared in this scope
Components_tester:615: error: 'DischargeProbes' was not declared in this scope
Components_tester:621: error: 'lcd_testpin' was not declared in this scope
Components_tester:622: error: 'lcd_data' was not declared in this scope
Components_tester:623: error: 'lcd_space' was not declared in this scope
Components_tester:624: error: 'DisplayValue' was not declared in this scope
Components_tester:629: error: 'CheckProbes' was not declared in this scope
Components_tester:644: error: 'lcd_clear_line' was not declared in this scope
Components_tester:646: error: 'lcd_data' was not declared in this scope
Components_tester:649: error: 'MeasureCap' was not declared in this scope
Components_tester:708: error: 'ShowError' was not declared in this scope
Components_tester:711: error: 'ShowDiode' was not declared in this scope
Components_tester:714: error: 'ShowBJT' was not declared in this scope
Components_tester:717: error: 'ShowFET' was not declared in this scope
Components_tester:720: error: 'ShowIGBT' was not declared in this scope
Components_tester:723: error: 'ShowSpecial' was not declared in this scope
Components_tester:729: error: 'ShowResistor' was not declared in this scope
Components_tester:732: error: 'ShowCapacitor' was not declared in this scope
Components_tester:735: error: 'ShowFail' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'byte ShortedProbes(byte, byte)':
Components_tester:807: error: 'ReadU' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void DischargeProbes()':
Components_tester:853: error: 'ReadU' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void CheckProbes(byte, byte, byte)':
Components_tester:1050: error: 'ReadU_5ms' was not declared in this scope
Components_tester:1075: error: 'CheckDepletionModeFET' was not declared in this scope
Components_tester:1106: error: 'CheckBJTorEnhModeMOSFET' was not declared in this scope
Components_tester:1127: error: 'CheckThyristorTriac' was not declared in this scope
Components_tester:1131: error: 'CheckBJTorEnhModeMOSFET' was not declared in this scope
Components_tester:1144: error: 'CheckDiode' was not declared in this scope
Components_tester:1150: error: 'CheckResistor' was not declared in this scope
Components_tester:1157: error: 'VerifyMOSFET' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'unsigned int ReadU(byte)':
Components_tester:1181: error: 'waitus' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void CheckResistor()':
Components_tester:2329: error: 'CmpValue' was not declared in this scope
Components_tester:2341: error: 'CmpValue' was not declared in this scope
Components_tester:2348: error: 'CmpValue' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'signed char CmpValue(long unsigned int, signed char, long unsigned int, signed char)':
Components_tester:2391: error: 'NumberOfDigits' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void lcd_clear_line(unsigned char)':
Components_tester:3123: error: 'lcd_data' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void lcd_testpin(unsigned char)':
Components_tester:3136: error: 'lcd_data' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void lcd_space()':
Components_tester:3142: error: 'lcd_data' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void lcd_string(char*)':
Components_tester:3150: error: 'lcd_data' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void lcd_fixed_string(const unsigned char*)':
Components_tester:3159: error: 'lcd_data' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void LoadAdjust()':
Components_tester:3961: error: 'ReadEEP' was not declared in this scope
Components_tester:3973: error: 'SaveEEP' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'byte SelfAdjust()':
Components_tester:4351: error: 'ShowAdjust' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void SaveEEP()':
Components_tester:4518: error: 'EEPROMWriteInt' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void ReadEEP()':
Components_tester:4539: error: 'EEPROMReadInt' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void MainMenu()':
Components_tester:4652: error: 'LcdMenu' was not declared in this scope
C:\Users\Mártika\Desktop\Components_tester\Components_tester.ino: In function 'void LcdMenu()':
Components_tester:4712: error: 'MenuTool' was not declared in this scope
exit status 1
In your diagram the switch is connected with A3 and GND, which change should i
do ?
I'm sorry Chauhan but your new diagram does not include any change
Hello Chauhan
U R G E N T I need your help
i did your project Arduino
Components Tester with Arduino One and it work but only comes out on the LCD screen
your name.
Does it Works with arduino one ?
Sorry for my english
After connecting any components you should press the push button.
Thank for your answer
Yes, but not working well.
I already bought an Arduino Nano and i'll try it today
