Arduino Control Servo Motor Using Ultrasonic Sensor
966
5
Posted in TechnologyArduino
Introduction: Arduino Control Servo Motor Using Ultrasonic Sensor
In this project you can see how can we control servo motor using arduino and ultrasonic sensor.
How the project work :
when ultrasonic sensor read 5cm distance ore less servo will rotate in 120 degree , else servo will rotate 0 degree
Arduino will print the distance on serial print . You can change the code easy if you need to do other things.
HardwarePut the trigpin of ultrasonic sensor in pin 7 on arduino. Put the echopin of ultrasonic sensor in pin 6 on arduino. Put vcc pin of ultrasinic sensor to 5v on arduino. Put servo to pin 8 on arduino. Put gnd of ultrasonic to gnd on arduino. and connect arduino with Pc.
Code:
#include
#define trigPin 7
#define echoPin 6
Servo servo;
void setup()
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
servo.attach(8);
void loop()
long duration, distance;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance < 5)
Serial.println("the distance is less than 5");
servo.write(120);
else
servo.write(0);
if (distance > 60 || distance <= 0)
Serial.println("The distance is more than 60");
else
Serial.print(distance);
Serial.println(" cm");
delay(500);
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
