Arduino ControlWare-Perform Tasks without reprogramming the Arduino
 by indiantinker
Hi Guys!
I have made a small GUI with which you can control arduino and perform tasks like analogReads,Digital Outputs etc..and several other tasks too. I made this with an idea to debug Circuits using Arduino. It helps a lot when you need to just study the behavior of a digital device..or sniff through the wiring of the circuit.
You can measure the AnalogValues on the analog Pins too..So,In case you want to check High/Low so, you will get the value as 0 (nearly) for LOW and 1023 for HIGH. similarly..you can measure the analog response of any other nature also..provided the 'Measured'  qty stays less than +5V !
Edit: If you like the instructable..Plz Plz Plz do vote for the Contest! Its on the banner right above this Instructable..Hack It contest..
You do need .NET Framework to run the controlWare.You can download it from: Here!
Step 1: Prepare the Arduino
Nothing much to do..just burn/upload the following sketch. You can download the same from my skydrive:
SketchHere!
Now just go ahead and download the same..and upload to the Arduino!
indiantinker (author) says: Nov 1, 2012. 1:22 AM
Thanks! You do need .NET for it..i will add it in the instructable !
Cheers,
Rohit
tcvella says: Oct 30, 2012. 7:07 PM
To run ControlWare, it required the .NET framework 4.0.
This is a download link for those who didn't have.
http://www.microsoft.com/en-us/download/confirmation.aspx?id=17851
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
