3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Arduino Controlled Bell Tower/Carillon
This is a set of musical bells which are driven by solenoids and controlled by an Arduino microcontroller.
There are 8 bells covering one octave.
The bells are controllable from a PC, or the tower can stand alone and play pre-programmed melodies.
Check out the final page for video of it in action.
Step 1Parts
Parts
The following parts were used:
1 set of chromatic handbells. I got these from my local Aldi for $20. They span the range from C to C. (I.e. c,d,e,f,g,A,B,C).
Wood panel & brackets to hold the bells and solenoids in place. $10.
8 Solenoids to strike the bells. I had these laying around in my junk box. I got them from a typewriter repairman who was throwing them away. You can probably find similar on Ebay.
Arudino microcontroller. ~$45. I got mine from SparkFun electronics.
Proto/Perf board & misc components to make my custom 'shield' for the arduino. $10.
Darlington driver board. I used one I had laying around, but I believe they're not sold separately. Should be possible to make it using the ULN2803 chip for a couple of dollars.
10 comments
Jun 14, 2010. 11:42 PMrobotmaker123 says:
i use those bells in music class
Apr 16, 2009. 8:01 PMDIY-Guy says:
Handbell choir in a box! Can we do wind chimes with these too?
Mar 29, 2009. 9:21 AM02.anand.m says:
It is a nice one. why can't u do interfacing using Processing?http://www.processing.org.
Dec 1, 2008. 11:11 AMRaisedByRobots says:
those bells are cool. I wish I could get some
Dec 1, 2008. 5:30 AMPKM says:
I'm pretty sure the Futurama theme has sharps in it so you probably can't play it on your setup as it is at the moment. I recommend hitting the charity shops for a children's "I can play t3h piano" book of simple "white notes only" tunes, or maybe getting more bells! You could always get a box of cheap wine glasses and some water.. :P
Nov 30, 2008. 8:58 PMthreebean says:
Just out of curiosity, where did you get that darlington array board. That looks like it would be handy to have. Thanks!
Nov 30, 2008. 12:56 PMAndyGadget says:
I like this. How about a simplified version omitting the Arduino, using the PC's parallel port instead. You can also pull 5v from this.
I don't know about Futurama but "Over the Rainbow" fits into one octave. (I worked it out for a kalimba .)
Nov 30, 2008. 9:18 AMalex-sharetskiy says:
Awesome indeed!
Nov 29, 2008. 9:02 PMfalafelcakes says:
This is awesome! Now I just need to learn Arduino...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:mechatronics
