Once I knew that this was a one of a kind idea, I drew up a rough plan on google sketchup to act as a starting schematic. I wanted to build the main chasis out of wood using mostly handtools so anyone could build one without a wood shop. The actuator (the crushing part) is driven by a old windshield wiper motor that my dad had laying arround, attached to two threaded rods by a belt and pulley system. There was an arduino that was sitting arround the house doing nothing, so there was no question that that would be the brains.
Remove these ads by
Signing UpStep 1: Tools and Parts
Minimum tools required:
Safty goggles
Hearing protection
Hand saw
Drill
Drill bits- 5/8, 1/2, 1/4, 1/8
Cross tip bit or screwdriver.
Hammer
Exacto knive
Vicegrips or adjustable wrench
Soldering Iron
Ruler
Pencil or pen
Materials required:
Plywood
1"x4" board
(2ea) 1ft, 1/2" threaded rods
(2ea) 1/2" couplers (remember to make sure the threading is the same as the rods)
(1ea) 3ft 1/4" smooth rod
(2ea) 1/2"ID 1-1/2" OD pulleys
(25ea) #8 x 1-1/4" Screws
(1ea) 1ft 1/4" threaded rod
(4ea) 1/4" nuts
(2ea) 1/4" ID large OD washers
(2ea) 1/4" lockwashers
(2ea) 1/2" OD washers (ID same as the motor shaft)
1/2" belt (diameter about 20")
Fence pole mount
Plastic clothesline puley
Soda can box
Epoxy
Arduino
Large 12v motor (power window motor or windshield wiper motor)
Solder
Wire
1602 LCD screen
Project box
1/2" Cable wrap
(2ea) Zipties
(3ea) Limit switches (SPDT submini lever switch)
Protoboard
Motor controller
Pins
Optional materials:
Sandpaper
Spray paint
Visit Our Store »
Go Pro Today »
when im done ill post mine with my schematic
thanks in advance.
Also, I am a beginner with Arduinos, so I am not sure what to do and how to wire all that up... Is there a possibility to make the crusher without the LCD screen and to make the crusher just crush when I turn it on (with an optional switch)... Thank you very much in advance! =D
One question- what is arduino?
Way to go!
Love
Your cousins in Alabama
A video?
i hope you dont mind me asking but are you using Circuit Wizard? (first pic - step 4)
XD...
Great project!!!
you should record a video of it in action, it must be awesome :D
If it's a front windshield wiper motor, it usually has wire for high speed, low speed and power, the ground sometimes does not have a wire.
The gearbox has a built in switch that stops the motor in certain position (so the wipers don't stop in the middle of the windshield).
If you connect 12 V to the power wire and the motor to the ground it doesn't turn, or only turns part of a circle and then stops. If you then momentarily connect 12 V to high or low speed wires the motor will start turning, but not stop until the circle has been completed. If you disconnect the power wire then the motor will start and stop as soon as you connect and disconnect 12 V to high or low speed wires.
But to clear things up, I should have included the wiring of the windshield wiper motor. I attached a wire from the frame of the motor and the wire that goes to direcly to the motor, bypassing the little switch that changes the direction.
I didn't like the results with the wind shield wiper motor, it isn't too fast (I know other motors could have much better results, but that's all I had to work with). The lever arm was taken off of the motor before I got it. I believe there is a picture of it in the Instuctable showing what the motor looked like.
It is an old model of a winshield wiper motor, I think from a GM based RV.
The rate depends on the speed of the motor you use. I used an old windshield wiper motor-- It is a little too slow. I believe if you use a motor from a "powerwheels" you should be able to crush them fast.
The automation is likewise quite ingenious, but I could see a lot more people (myself included) building this a manually-operated device, with a simple switch to initiate the cycle, and perhaps a limit-switch to stop it. Automation could be added later if desired..
It crushes cans using the force created by the linear actuators (threaded rod moving the crusher).
A simple circuit could be made using the same setup with a SPDT switch connected to a DPDT relay which controls the direction of electricity going into the machine. the limit switches can still be used to create an open so that the machine doesn't go too far in or out.
There are 3 switches already on this to make it automated.
One is in the hopper ("the chute") to tell the machine: hey we got something to crush, and one at the open and closed ends of the crusher to tell it: go this way, now turn arround and go back as soon as it gets to one switch, and stops if there are no more cans in the hopper.
It works like this: The switch at the extended crusher position is triggered and the feed switch (in the hopper ["the chute"]) is triggered, the process begins. Once the machine crushes the can, a switch is closed telling the machine to extend the crusher (which releases the crushed can) and returns to the start position once the switch is pressed. Once the switch returns home one more can is added.
It isn't done by time, any size/speed motor would work as long as it can drive the pulleys. I can make another schematic with the DPDT relays in there for you if you want--free of charge.
I think the fun part is designing and building it; as well it doing the crushing, counting, and weighing for you. All you have to do is drink and put your empties in the chute.
I hope this better explains how it works.
How long does it take to crush each can?
It takes about 30 seconds; each revolution by the big pulley is about two revolutions of the smaller ones. I believe if you use some moters from a "power-wheels" and went to a sprocket and chain system, the speed should increase and decrease the time to about 10 seconds per can.
I would love to put a video up but finals week is almost here.
