Step 2Assemble the circuit
- Attach the resistors
- Attach the diode
- Attach the transistor
- Attach the three pin screw terminal
- Attach the two pin screw terminal
- Attach the LED
- Attach the Relay
Put the relay on last because it gets in the way if you don't. You will find it to be a little tight against the two pin screw terminal, but that is ok because it still fits. You don't have to use the two pin screw terminal either and can opt to solder the extension cord directly to the board, but I decided against that for useability.
Add Comment
