3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Arduino Controlled Relay Box
Step 3Splicing the Wires
Splicing the Wires
When you splice the extension cord wires you are likely to see one of two things.  Either your cord has three different color wires or it doesnt, but there ought to be three or this project won't work.  The three cords are as follows:
  • Green - Ground Return
  • Black - Hot Wire
  • White - Neutral Wire
If your extension cord does not have three wires then you'll have a green wire in the middle, one smooth wire on one side which carries the voltage (The Black Wire), and one wire with ridges on the other side (The White Wire).  Double check these before you make any live electrical connections.  Even I messed this up and caught it just in time.
Your going to cut the extension cord about a foot from the end of the female plug.  Then split the three wires about 6 inches down.  Cut the black wire five inches from the end.  This should give you about one inch attached to the cord and a 5 inch extension that will go from your relay board to the outlet.
Next strip and tin the end of all the wires.  It's likely your wires are a collection of smaller wires, twisting them before tinning is a big help.  Then lay out everything and check it before moving on.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:natantus(Chris Gilmer Project)
I'm a software and aerospace engineer. When I've got free time I like to work on robot projects and love to play with my Makerbot Cupcake and Eggbot. I would love to be involved in DIY prosthetics a...
more »
