Arduino - DigitalRead Serial Monitor With Button
4,190
38
Published
Introduction: Arduino - DigitalRead Serial Monitor With Button
About: For more project and tutorial visit my YouTube channel Mert Arduino and Raspberry Pi
This example shows you how to monitor the state of a switch by establishing serial communication between your Arduino or Genuino and your computer over USB.
Step 1: ​digitalRead()
Description
Reads the value from a specified digital pin, either HIGH or LOW.
Syntax
digitalRead(pin)
Parameters
pin: the number of the digital pin you want to read (int)
Returns
HIGH or LOW
Reference : https://www.arduino.cc/en/Reference/DigitalRead
Step 2: Hardware Required
  • Arduino Uno
  • Button
  • 10k ohm resistor
  • Wires
  • Breadboard
Step 3: Connections
  1. Button attach to breadboard
  2. One leg of the button connect a resistor
  3. The wire connect to digital pin to one leg of the pushbutton
  4. Empty leg of the resistor to ground (GND)
  5. Other leg of the button connect to +5V
Step 4: Code
// This example code is in the public domain
int pushButton = 2;
void setup() {
Serial.begin(9600);
pinMode(pushButton, INPUT);
void loop() {
int buttonState = digitalRead(pushButton);
Serial.println(buttonState);
delay(1);
//reference https://www.arduino.cc/en/Tutorial/DigitalReadSerial
Step 5: If It Helps, Please Subscribe
First of all, I would like to thank you for reading this guide ! I hope it helps you.
If you want to support me, you can subscribe my channel and watch my videos.
Mert Arduino Tutorial & Projects
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
