Arduino Door Locking System
Published
Introduction: Arduino Door Locking System
In this project I made an door lock (or box lock) that opens when you enter your password and press "*".
Step 1: Material Needed....
1. Arduino uno
2. Standard Servo
3. Red And Green LED
4. Male And Female Pin Headers
5. Door Lock
6. 4X4 Keypad
7.PCB
Step 2: Make PCB ....
Solder all the connection as shown above in the pics.
Or use frtizing file attached below
Step 3: Make Door Opening System....
Using Double tape Stick servo And Using A thick metal wire make a system that can open the lock when servo moves my pics above will help you..
Step 4: Put Every Thing Together
Put everything in order as shown in pics above
Step 5: Upload the Code on Arduino ..
Code Link :- https://drive.google.com/file/d/0B-ucVP7iDSacOTd3d...
Code :-
#include //http://playground.arduino.cc/uploads/Code/Password.zip //tells to use password library
#include //http://www.arduino.cc/playground/uploads/Code/Keypad.zip //tells to use keypad library #include //tells to use servo library
Servo myservo; //declares servo Password password = Password( "0000" ); //password to unlock, can be changed
const byte ROWS = 4; // Four rows const byte COLS = 4; // columns // Define the Keymap char keys[ROWS][COLS] = { {'1','2','3'}, {'4','5','6'}, {'7','8','9'}, {'*','0','#'} }; // Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins. byte rowPins[ROWS] = { 9, 8, 7, 6 };// Connect keypad COL0, COL1 and COL2 to these Arduino pins. byte colPins[COLS] = { 5, 4, 3 };
// Create the Keypad Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){ Serial.begin(9600); Serial.write(254); Serial.write(0x01); delay(200); pinMode(11, OUTPUT); //green light pinMode(12, OUTPUT); //red light myservo.attach(13); //servo on digital pin 9 //servo keypad.addEventListener(keypadEvent); //add an event listener for this keypad }
void loop(){ keypad.getKey(); myservo.write(180); } //take care of some special events void keypadEvent(KeypadEvent eKey) { switch (keypad.getState()){ case PRESSED: Serial.print("Enter:"); Serial.println(eKey); delay(10); Serial.write(254); switch (eKey) { case '*': checkPassword(); delay(1); break; case '#': password.reset(); delay(1); break; default: password.append(eKey); delay(1); } } } void checkPassword(){ if (password.evaluate()) { //if password is right open Serial.println("Accepted"); Serial.write(254);delay(10); //Add code to run if it works myservo.write(0); //deg digitalWrite(11, HIGH);//turn on delay(10000); //wait 5 seconds digitalWrite(11, LOW);// turn off } else { Serial.println("Denied"); //if passwords wrong keep locked Serial.write(254);delay(10); //add code to run if it did not work myservo.write(180); digitalWrite(12, HIGH); //turn on delay(5000.); //wait 5 seconds digitalWrite(12, LOW);//turn off } }
Step 6: Run the Device ..
Power The Arduino And test everything...
Default password is 0000
Step 7: How to Change Password
As Shown in Pic Above Change the Highlighted Number ...
and upload the code.....
Frtizing file :-https://drive.google.com/file/d/0B-ucVP7iDSacSnpZR...
or
https://drive.google.com/file/d/0B-ucVP7iDSaccDdGV...
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    Hello,
    Good job, i used the code for another project.
    Just a tips :
    If you don't reset the password when it's accepted, it still in memory.
    So, if you just press the validate key, it's OK and that opens the door.
    Better to use password.reset() after each time it's validate
    When i execute program i m getting like this please help
    Arduino: 1.6.11 (Windows 7), Board: "Arduino/Genuino Uno"
    sketch_aug24a:1: error: #include expects "FILENAME" or <FILENAME>
    sketch_aug24a:2: error: #include expects "FILENAME" or <FILENAME>
    exit status 1
    This report would have more information with
    "Show verbose output during compilation"
    option enabled in File -> Preferences.
    HI SIR,
    Should I include #include //http://playground.arduino.cc/uploads/Code/Password.zip //tells to use password library while programming ????
    Cool! This is a nice looking little locking system. Thanks for sharing!
    Welcome My Pleasure...
