Arduino Tutorial Bundle .:Arduino Experimentation Kit:. (ARDX)
PrintPrint PDF FacebookFacebook TwitterTwitter Send this to a friendE-mail
by oomlout
introArduino Tutorial Bundle .:Arduino Experimentation Kit:. (ARDX)
Interested in making neat projects with an Arduino but not sure where to start?
Here's an easy to follow guide on how to connect & use a bevy of electronic components.
(shameless plug)
Interested in doing it all?
Complete kits with components to make every circuit, a printed guide and breadboard layout sheets can be purchased from.
oomlout.co.uk (in the UK)
or
adafruit.com (USA & International Shipping)
or
Floris.cc (in Holland)
Lets get started!
(A PDF Version of this guide can be downloaded below)
Jump to a specific copmonent
'''CIRC-01''' - Getting Started - (Blinking LED)
'''CIRC-02''' - Multiple LEDs - (8 LED Fun)
'''CIRC-03''' - Spin Motor Spin - (Transistor & Motor)
'''CIRC-04''' - A Single Servo - (Servos)
'''CIRC-05''' - 8 More LEDs - (74HC595 Shift Register)
'''CIRC-06''' - Music - (Piezo Element)
'''CIRC-07''' - Button Pressing - (Push Buttons)
'''CIRC-08''' - Twisting - (Potentiometers)
'''CIRC-09''' - Light - (Photo Resistors)
'''CIRC-10''' - Temperature - (TMP36 Precision Temperature Sensor)
'''CIRC-11''' - Larger Loads - (Relays)
(at oomlout we like to make everything we do open source, we have yet to properly document the files that have gone into this product however the development files can be looked through at http://www.oomlout.com/ARDX/ or if you can't find a file send us a message and we'll send it your way)
Remove these adsRemove these ads by Signing Up.
step 1.: Installing the Software :.
Before we go any further you'll need to download and install the Arduino IDE (Integrated Development Environment), this is the program we use to write programs for the Arduino.
Step- 1 - Download the IDE
FOR WINDOWS'
Step-2- Unzip the software
  • Unzip the program. (we recommend placing it in c:\Program Files\)
Step-3 - Shortcut Icon
  • Goto C:\Program Files\Arduino-00**
  • Right click on Arduino.exe the goto "Send To > Desktop"
Step-4 - Plug In Your Arduino
  • Plug your Arduino board into a free USB port using an A-B USB cable
  • Wait for a box to pop up
Step-5 Add New Hardware
  • In the add new hardware dialog box click "skip searching the internet"
  • Choose "install from a specific location"
  • Choose the location "C:\Program Files\Arduino-00**\drivers\FTDI_USB_Drivers\
  • FINISHED
FOR MAC OSX'
Step 2 - Unzip the Software
  • Do this by double clicking
  • Move the folder to "//Applications/"
Step 3 - Alias Icon
  • Open //Applications/arduino-00**/
  • Command click Arduino
  • Make alias
  • Drag the alias to the Desktop
Step 4 - Installing Drivers
  • Goto //Applications/arduino00**/drivers
  • Double click and install FTDIUSBSerialDriver_V2_2_9_Intel.dmg
Step 5: Plug in your Arduino
  • Plug your Arduino in
Using linux, encountering problems, would like more details? visit http://tinyurl.com/r99d8u
To Download the PDF or View All Steps,
Become a Pro Member »
36 comments
Jul 18, 2010. 6:31 PMbiggestnoob says:
Hi there, I am wondering if I can run my dc motor reverse. is there any special code to make it reverse? if there is, please tell me. thank you,
Apr 13, 2010. 1:43 AMSchwann says:
 Hey, just thought I'd let you know that the example from arduino.cc uses a pull-down configuration while your circuit uses a pull-up configuration, so the LED on/off is reversed (:
Oct 25, 2009. 10:01 AMdadoftwins says:
Where is the code for this project? Can't find it anywhere.
Apr 4, 2010. 9:59 PMrobotjam says:
The code is just below the video and goes all the way to the right and i mean ALL the way
Feb 13, 2010. 10:10 AMeshneto says:
 Hello there, nice job,thanks! Maybe you could help me here.
I am trying to figure out why is the 2.2k resistor required? I have seen in the transistor datasheet something like "Emitter-Base voltage = 6.0Vdc", doesn't it mean that we could plug the device directly to Arduino?
I am trying to figure out if I may use a 2N60B instead, since I have one of these here. I just don't know why would I need a resistor.
Thanks in advance.
P.S.: The code appears without line breaking (using google-chrome for Linux) for me.
Feb 14, 2010. 1:49 PMolmstw says:
You ask very intelligent questions... (NO sarcasm intended)
The 2N60B, however would not be a good choice here, as it is a MOSFET not a JUNCTION transistor.  The gate voltage required for full turn-on is 10V, TWICE the output voltage of the Arduino.   Also, the Rds(on) of the 2N60B with 10V applied to the gate can be as high as 5 ohms. This means that the transistor behaves as if there were a 5 ohm resistor in series with the output.  If the Motor draws any kind of current at all, the votage dropped across the transistor (Drain to Source) would cause the motor to run slow (or not at all).
You can see the data sheet here: http://pdf1.alldatasheet.com/datasheet-pdf/view/54779/FAIRCHILD/2N60B.html
A better choice, in this case, if you cannot find a 2N2222, would be a 2N3904.
Wayne
Feb 14, 2010. 1:17 PMolmstw says:
The "Emitter-Base voltage = 6.0Vdc" statement may be the confusing thing here; The maximum REVERSE voltage that may be applied to the Base-Emitter junction is ~6V But the normal FORWARD drob across the base-emitter junction is approximately 0.7V...  The current into the base MUST be limited to prevent the transistor form being distroyed be excessive base current.
Since the 0.7V forward base voltage is significantly less than the 5V output of the Arduino port pin, then the current flowing into the base of the transistor would likely exceed the rated maximum of both the Arduino pin AND the rated maximum input current od the base of the transistor.
The function of the resistor is to prevent damage (caused by excessive current) to either the transistor or the Adrion.
Feb 14, 2010. 9:11 PMeshneto says:
 Thank you for your attention ;)
I found the mentioned info in the dataheet. Still I did not understand some details, however. How do I get to the 2.2k value? Am I supposed to assume a 2mA current at the base so that r=v/i=4.3/0.002=2150? How do I get that info in the sheet?
I am right now using a photocoupler to do the job of swtching the motor, I will make an instructable soon, but I still am not sure about the resistor values.
Feb 15, 2010. 6:11 AMolmstw says:
If you are using a bipolar transistor (2n2222, 2n3904 etc), read the data sheet...
1. determine the current that the transistor must switch and divide it by the Hfe (current gain of the transistor at the desired load current per the data sheet)
2. multiply the result by 2 (safety margin)....  this is the ideal base current for your application
3. subtract 0.7V (the base-emitter drop) from the drive voltage from the Arduino pin (use the data sheet and the Minimum guaranteed Vh out.
4. divide this number by the base current you determined in 2 above.
5. this is the base resister value you need to use.
works every time ^_*
Feb 15, 2010. 8:21 AMeshneto says:
 Thanks, that's what I wanted to know: how to determine the base current. Now I know it is obtained by dividing the switched current by the transistor's Hfe.
Again thanks a lot!
Feb 3, 2010. 11:36 AMcefn says:
The code for circuit 02 is at http://tinyurl.com/dkpxbn
Feb 3, 2010. 6:01 AMStoned says:
I just bought an arduino and I would like to try doing these projects, but I have hit some trouble. I am confused when it comes to the shift registers. When you say to connect to the clock pin, do we connect to the SCK (Shift Register Clock Input) or the RCK (Storage Register Clock Input)? When you say to connect to the data pin, do you connect to the SI (Serial Data Input)? Also What do you mean when you say to connect to the latch pin?
The data sheet for the Digikey shift register I am using is in the link below.
http://www.fairchildsemi.com/ds/MM/MM74HC595.pdf
Oct 8, 2009. 7:35 AMRencio7 says:
 LEDs are around the wrong way on the left side of the diagram - I think -Im new to this stuff -I. :(  it was a bit annoying testing each part of the circuit - and matching it up to a wrong diagram..
Oct 8, 2009. 8:08 AMRencio7 says:
 *make that both sides :P yay it works !
Dec 8, 2009. 2:40 PMSplooshiba says:
 i just got my arduino and have been playing with the code, but with no luck. What is the output from this code with NO changes made what so ever.
Where do changes need to be made to change the LEDs which light. Advice would be much appreciated, many thanks.
Dec 25, 2009. 8:56 PMpben says:
On LEDs the long lead (metal leg) is the Anode (+) and the flat side of package at the base of the dome is the cathode (-).  The diagram for CIRC-01 has that reversed.
The Anode and Cathode names are a hold over from the old days when diodes were vacuum tubes (valves for you Europeans out there).   Good news no damage will be done if they are put in backwards on this circuit.  It will jest not light the LED but the on-board LED will still flash.
Nov 27, 2009. 9:37 PMachollowell says:
I got my Arduino starter kit from amazon.com and also a book wrote by one of the co-founders of Arduino book very helpful guide you step by step
Oct 18, 2009. 12:51 AMemadd says:
hello i need code with asm
Aug 24, 2009. 9:28 AMyene says:
I had to modify the relay because the pins were to short.
Jun 18, 2009. 5:02 PMgrundisimo says:
What is an arduino??????????????????
Jun 24, 2009. 6:40 AMGjdj3 says:
Ahem.
Arduino is an open-source electronics prototyping platform based on flexible, easy-to-use hardware and software. It's intended for artists, designers, hobbyists, and anyone interested in creating interactive objects or environments.
Jun 19, 2009. 3:19 AMdigigalos says:
¿And for GNU/Linux?
Jun 20, 2009. 9:18 AMdigigalos says:
Hi, Atuart.Mcfarlan. Thanks for the link. You don't worry about forgetting, the users of GNU / Linux are accustomed to it, this is the price we pay for our freedom.
Jun 18, 2009. 8:44 AMnatantus says:
Great Instructable! Very thorough and readable. I especially like the exploded 3D models of the circuits. Keep up the good work!
Jun 18, 2009. 6:41 AMGaark says:
Wow! Nice big chunk of info I will find very handy as a newbie to programmable bizzos. Thanks heaps for putting it here!!
Jun 16, 2009. 11:50 AMBongmaster says:
nice ible very detailed and well documented :) tho zone alarm is blocking tinyurl as a spy site :S so i couldnt look at the link u provided about shift registers. and i could do with learning about them XD
Jun 16, 2009. 3:14 PMvidakk says:
Jun 17, 2009. 1:02 AMBongmaster says:
thnx 4 the 1st link ;) as for the second.. yea ok , i was referring to his exact link (googleing was the 1st thing i did duh, more info is good info) lmgtfy is fast becoming the lowest form of wit XD
Jun 17, 2009. 3:00 PMvidakk says:
Yeah, 'twas lame, I know. Sorry.
Jun 17, 2009. 8:58 PMBongmaster says:
Jun 16, 2009. 3:11 PMtheformatter says:
I like it, good use of examples and pictures. You've obviously spent a good bit of time working on this and your effort is appreciated. I do have one question, though, and it's probably related to theory vs. real-world. On step 4, "8 LED Fun", why did you use 8 resistors? Could you use one resister that is placed between the negative of all the LED's and ground? I understand that it would have to have a higher power rating, but it seems like it would simplify things quite a bit to use a single beefier resistor than 8 small ones. Thanks! Jim
Jun 16, 2009. 12:20 PMfrollard says:
Incredible account of 'how to get started'! 5 from me...and well deserved!
May 18, 2009. 9:06 PMMr.Clodex says:
Nice work really love all the effort you have put into this, hope people buy. Maybe to more "CIRC" projects to add: Digital Display And Speakers / Pezo
