loading
Step 12: .:Temperature:. (TMP36 Precision Temperature Sensor) - CIRC10
What We're Doing:
What's the next phenomena we will measure with our Arduino? Temperature. To do this we'll use a rather complicated IC (integrated circuit) hidden in a package identical to our P2N2222AG transistors. It has three pins ground, signal and +5 volts, and is easy to use. It outputs 10 millivolts per degree centigrade on the signal pin (to allow measuring temperatures below freezing there is a 500 mV offset eg. 25 degrees C = 750 mV, 0degrees C = 500mV). To convert this from the digital value to degrees we will use some of the Arduino's maths abilities. Then to display it we'll use one of the IDE's rather powerful features, the debug window. We'll output the value over a serial connection to display on the screen. Let's get to it.
One extra note, this circuit uses the Arduino IDE's serial monitor. To open this, first upload the program then click the button which looks like a square with an antennae.
The TMP36 Ddatasheet:
http://tinyurl.com/plbx38
(you can also download the breadboard layout sheet from the bottom of this step)
The Parts:
  • CIRC-10 Breadboard Sheet
  • 2 Pin Header (x4)
  • Temperature Sensor (TMP36) (x1)
  • Wire
The Circuit and Plugging Everything In:
A Small Video of Everything Being Plugged in
The Code: - http://tinyurl.com/dfj8rs
/* --------------------------------------------- * |  Arduino Experimentation Kit Example Code | * |  CIRC-10 .: Temperature :.                | * --------------------------------------------- *     *  A simple program to output the current temperature  *  to the IDE's debug window   *  For more details on this circuit:  *  http://tinyurl.com/c89tvd  *///TMP36 Pin Variablesint temperaturePin = 0;//the analog pin the TMP36's                        //Vout pin is connected to                       //the resolution is                        //10 mV / degree centigrade                                                //(500 mV offset) to make                        //negative temperatures an optionvoid setup(){  Serial.begin(9600);  //Start the serial connection                         //with the copmuter                       //to view the result open the                        //serial monitor                                               //last button beneath the file                        //bar (looks like a box with an                        //antenae)} void loop()                     // run over and over again{ float temperature = getVoltage(temperaturePin);             //getting the voltage reading from the            //temperature sensortemperature = (temperature - .5) * 100;//converting from 10 mv                       //per degree wit 500 mV offset to                       //degrees ((volatge - 500mV) times 100) Serial.println(temperature); //printing the result delay(1000);                 //waiting a second}/* * getVoltage() - returns the voltage on the analog input  * defined by pin */float getVoltage(int pin){ return (analogRead(pin) * .004882814);//converting from a 0                        //to 1024 digital range                       // to 0 to 5 volts                        //(each 1 reading equals ~ 5 millivolts}
Not Working?
  • Nothing Seems to Happen - This program has no outward indication it is working. To see the results you must open the Arduino IDE's serial monitor.
  • Gibberish is Displayed - This happens because the serial monitor is receiving data at a different speed than expected. To fix this, click the pull-down box that reads "*** baud" and change it to "9600 baud".
  • Temperature Value is Unchanging. - Try pinching the sensor with your fingers to heat it up or pressing a bag of ice against it to cool it down.
(instructions on previous page)
Making it Better:
Outputting voltage:
This is a simple matter of changing one line. Our sensor outputs 10mv per degree centigrade so to get voltage we simply display the result of getVoltage().
delete the line temperature = (temperature - .5) * 100;
Outputting degrees Fahrenheit:
Again this is a simple change requiring only math. to go degrees C ----> degrees F we use the formula.
( F = C * 1.8) + 32 )
add the line
temperature = (((temperature - .5) * 100)*1.8) + 32; before Serial.println(temperature);
More informative output:
Lets add a message to the serial output to make what is appearing in the Serial Monitor more informative. To do this first revert to the original code then change:
 Serial.println(temperature); ----> Serial.print(temperature); Serial.println(" degrees centigrade");
The change to the first line means when we next output it will appear on the same line, then we add the informative text and a new line.
Changing the serial speed:
If you ever wish to output a lot of data over the serial line time is of the essence. We are currently transmitting at 9600 baud but much faster speeds are possible. To change this change the line:
  Serial.begin(9600); ----> Serial.begin(115200);
Upload the sketch turn on the serial monitor, then change the speed from 9600 baud to 115200 baud in the pull down menu. You are now transmitting data 12 times faster.
CIRC10-sheet.pdf(630x810) 43 KB
