Arduino FM radio receiver shield
This Instructable will show you how to build your own FM radio receiver shield to be used with an Arduino board. The radio chip we are going to be using is the AR1010 on a breakoutboard found at Sparkfun or Electrokit and there will be code to get you up and running provided later on. We are going to use an laser cutter for the shield fabrication.
Step 1Eagle 1
Eagle 1
First we build up our circuit using eagle. There are many Instructables out there on how to do it such as this or this. You can download my eagle files I have been using when building this board below. Things to consider is that when you are going to be using the laser cutter for doing pcbs you have to remeber that it is one sided pcbs that is be far easiest and also that the traces has to be 15 mil or wider otherwise the laser and etching process might etch them away.
17 comments
Jul 22, 2010. 1:09 PMdaveleb55 says:
so, how do you control the radio without having a computer attached to it? Seems like you could whack this together on a piece of perfboard without all the etching and messing about with Eagle files. Wouldn't be as pretty, but it would still work. Nice instructable, just the same. Thanks for posting, gives me ideas for future projects. DaveL
Sep 1, 2010. 5:02 AMcliffyd says:
well its may be easier but us guys who like o invent tend to make things look nice and not always take the easy "perfboard" way!
Jul 23, 2010. 8:21 AMardrhi says:
An Arduino is a small computer. That's what the software is.
Jul 22, 2010. 3:37 PMUziMonkey says:
It would be trivial to add a few buttons to control the radio. There are a lot of free IO pins on the Arduino. You can either make this into a true "shield" and stack another button shield on top, or make your own shield with both buttons and the radio.
Aug 2, 2010. 9:18 PMFoaly7 says:
You could add tuning controls to this and stuff it into certain casings, like an old NES cartridge, and listen with that.
Jul 23, 2010. 5:24 AMnavaburo says:
When I first saw this instructable, I was expecting the Arduino to have a more active role in the receiver. So far as I understand it, in this setup, the Arduino configures the receiver but has no idea what, if anything, is being received. Given the bidirectional nature of the I2C bus, I would expect the AR1010 to be capable of sending feedback to the Arduino. (However, the datasheet doesn't even specify the protocol!) With such an addition this could be a marketable shield. Nice work, I look forward to seeing future versions, Chris
Jul 23, 2010. 8:20 AMardrhi says:
It appears to be an exercise in "software defined radio", a new branch of radio design, where software takes the place of a lot of the hardware. It's getting popular in amateur radio as well, and is finding its way into military gear, since it can be reconfigured with a software change instead of rebuilding hardware. If something in a system gets compromised, change the software and it's no longer the same system. Here's a good page describing some of the work being done on SDR: http://www.arrl.org/software-defined-radio
Jul 22, 2010. 7:20 AMardrhi says:
*blink blink* Oh, ok, I get it. "Shield" is a term for Arduino gadgets, it doesn't shield you FROM FM. *Forehead smack* Duh. It's a nice Instructable...if someone has access to a 40w spray-paint etching laser table. There's a half-dozen ways to mask a PCB from that pretty picture (especially if the b/w are inverted) without using a laser to etch the paint, a technique that, while incredibly accurate, you must admit is a little bit out of pocket for most hobbyists. Seriously, I'd love one of those. I wonder if you can cobble one out of a TEA laser? I'd rather use something like Techniks press-n-peel, and simply iron on the PCB traces, then etch. After all, the Instructable is supposedly on how to make a radio from an Arduino, not "How to use a laser to etch a PCB". The instructions on the actual making the radio part seemed almost anticlimax..."now that you've finished these 6 detailed steps on laser-etching your board, solder the parts on, upload this program, and there it is." Bwuh? But maybe all this is just me. If you've got a laser, use it. And maybe no one else thought it shielded you from FM radio, not even for a second.
Jul 23, 2010. 6:50 AMBillDaCatt says:
No, you are not alone. I too had no idea what shield meant in this context. I have little to no experience with Arduinos and so the term was just confusing to me. In fact, I think sister-board, daughter-board, or control-board would have been much more appropriate than shield. (for those who don't know: In the context of radio, the word 'shield' implies that we want to block radio waves, not receive them. In this case, shield is used by the author to describe an FM radio board that sits on an Arduino board like a cover or a shield.) I also agree that this seems to be more about laser etching than it is about actually showing us how to make one. Cool project though!
Jul 23, 2010. 1:41 AMriverreaper says:
thats easy first you need to build it , find an old dvd player the laser they use will help you in your etchins , cource all mine just turn out in circals so far but im still learning how to use it. oh an i forgot to mention the glass magnifier lens , mines a bit old school as all i had on hand was one out of an anteak camcorder think its like 78mil zoom , i dont sugest trying at home thou as now i can watch the stars at night threw my new skylight , wich ive to go back up an add more serrandwrap to catch you latter home all goes better ;O)
Jul 23, 2010. 8:17 AMardrhi says:
A DVD laser is NOWHERE NEAR 40 watts. You might find a 200 milliwatt laser in a DVD burner. A Blu-Ray diode might give you 125-300mw. Maybe. You can get up to a 1W laser diode from laser light shows or projectors, and some sites actually sell harvested diodes of this type. (I know, I have one on its way for a different project.) But a 40 watt laser is most likely a CO2 gas laser used for CNC cutting or milling, not something you can cobble up from salvaged DVD sleds. You MIGHT find one used on eBay for a few thousand bucks, but again, it's a few thousand bucks, and they're not as easy to feed and maintain. That's why I was wondering if a TEA laser might be applicable to this use. It's a transversely excited laser using a high-voltage discharge across an air or nitrogen gap to create a pulsed ultraviolet laser. I don't know how much actual power one has, but it might be worth a try. Properly focused, it might do something. And for one of those, you'd put the work piece on your XY table, not the laser head...and it'd be a YZ wall at that point, not an XY table, I guess...digression, digression, digression... As for the "shield" thing...it just took me a minute. After all, there have been BASIC "Stamps" for a long time, little boards with chips on them you program with an abbreviated form of BASIC. The "Shield" nickname is a version of the same thing...calling the prototype board that bears an Arduino a "Shield" like calling the little board with that other chip on it a "Stamp". I just didn't remember the term right away.
Jul 26, 2010. 11:26 PMriverreaper says:
mine for the mos part was a jokeinly put fasion i find usen the oldfastion buck knive to cut just fine , but thats only if im up in the mountains an need to pull off a megiver move
Jul 22, 2010. 4:56 PMemerson.john says:
I have been building my own electronic equipment since I needed a selection of punches for the tube sockets. Do I need to get a laser engraving tool now?
Jul 22, 2010. 2:03 PMjuiceman74 says:
I'm missing a stage here. How did you get the printed schema onto the coated PCB? Does it have to do any thing with the paint? O>
Jul 22, 2010. 3:35 PMUziMonkey says:
The paint just shields the copper from the acid. What he actually did was use a laser cutter to remove the paint, essentially drawing the circuit in spray paint. Seems like a really great method, if you happen to have a laser engraver laying around (don't we all have one of those?). But you can use another method for this, like toner transfer.
Jul 20, 2010. 3:58 PMsxdemon says:
awesome!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:ZrvZ(Portfolio)
