loading
California is suffering from a debilitating drought.
When hasn't it, am I right?
Convert grass to gravel and ficus to cacti are all proposed options.
The absolute solution?
Desalinization pla--er, I mean, stop pissing away water!
Standard toilets use up to 6,500 mL (1.6 gal) of water to flush a standard person's 400 mL of urine twice a standard day. Hack most existing toilets with the Arduino Flush-Less and reduce waste by up to half with out replacing a single toilet. With just 1,825 AFL units installed, we could save 1,000,000 gallons a year, exclamation point.
// Arduino Flush-Less (1.0) _ TV Miller
// CapacitiveSensor Library _ Paul Badger
// PFOD _ Dr. Matthew Ford
#include
#include
#include
#include
pfodParser parser;
// Pin 6 (10M) and 5 (1K)
CapacitiveSensor deucetouch = CapacitiveSensor(6,5);
// Pin 7 (10M) and 8 (1K)
CapacitiveSensor flushtouch = CapacitiveSensor(8,7);
Servo tankservo;
Servo flushservo;
int tankOFF = 120;                // Tank Servo Position OFF
int tankON = 0;                   // Tank Servo Position ON
int flushOFF = 180;               // Flush Servo Position OFF
int flushON = 0;                  // Flush Servo Position ON
int bowlvalve = 10;               // Bowl Pin 10
int pooLED = 9;                   // LED Pin 9
void setup()
Serial.begin(9600);
for (int i=5; i>0; i--) {         // Wait
Serial.print(i);
delay(1000);
parserSetup();
Serial.println();
Serial1.begin(9600);              // Serial1 BlueTooth (Micro)
pinMode(bowlvalve, OUTPUT);
pinMode(pooLED, OUTPUT);
tankservo.attach(3);              // Tank Pin 3
flushservo.attach(4);             // Flush Pin 4
digitalWrite(pooLED, HIGH);       // Setup Alert
delay(1000);
digitalWrite(pooLED, LOW);
delay(1000);
delay(1000);
void loop()
// Turn OFF All
flushservo.write(flushOFF);       // Flush CLOSED
tankservo.write(tankOFF);         // Tank CLOSED
digitalWrite(bowlvalve, LOW);     // Bowl CLOSED
digitalWrite(pooLED, LOW);        // LED OFF
// Read Sensors
long tank_touch = deucetouch.capacitiveSensor(30);
long flush_touch = flushtouch.capacitiveSensor(30);
// Deuce, Flush or Stand By
     if (tank_touch > 1500 && flush_touch < 500){ numbertwo(); }
else if (flush_touch > 1500 && tank_touch < 500){ emptybowl(); }
else ( delay(10) );
// Print Sensors (Testing)
Serial.print(tank_touch);
Serial.print("\t");
Serial.println(flush_touch);
// Write Bluetooth Menu
if (Serial1.available()) {
byte in = Serial1.read();
byte cmd = parser.parse(in);
if (cmd != 0) {
if ('.' == cmd) {
 Serial1.print(F("{."));
 Serial1.print(F("HackADay Prize"));
 Serial1.print(F("|A~<+8>Deuce"));
 Serial1.print(F("|B~<+8>Flush"));
 Serial1.print(F("}"));
// Handle Bluetooth Buttons
} else if('A'==cmd) {             // Deuce
numbertwo();
 Serial1.print(F("{}"));          // Update
} else if('B'==cmd) {             // Flush
emptybowl();
} else {
// Deuce
void numbertwo() {
digitalWrite(pooLED, HIGH);       // LED ON
digitalWrite(bowlvalve, HIGH);    // Bowl OPEN
tankservo.write(tankON);          // Tank OPEN
delay(13000);                     /* Adjust Per Model */
return;
//Code To Lock Out NumberTwo()?
// Flush
void emptybowl() {
flushservo.write(flushON);        // Flush OPEN
delay(6000);
delay(2000);
delay(15000);                     /* Adjust Per Model */
return;
// BlueTooth Tasks
byte cmdByte;
byte parserByteCounter;
byte parserState;
static const byte pfodMaxMsgLen = 0xff;
static const byte pfodStartMsg = (byte)'{';
static const byte pfodEndMsg = (byte)'}';
static const byte pfodWaitingForStart = 0xff;
static const byte pfodInMsg = 0;
void parserSetup() {
parserByteCounter = 0;
cmdByte = 0;
parserState = pfodWaitingForStart;
byte parse(byte in) {
parserByteCounter++;
if (parserState == pfodWaitingForStart) {
if (in == pfodStartMsg) {
parserSetup();
parserState = pfodInMsg;
parserByteCounter = 1;
return 0;
if ((parserByteCounter == pfodMaxMsgLen) &&
(in != pfodEndMsg)) {
parserSetup();
return 0;
if (in == pfodEndMsg) {
byte pfodMsgCmd = cmdByte;
parserSetup();
return pfodMsgCmd;
} else if (cmdByte == 0) {
cmdByte = in;
return 0;
About This Instructable
91views
1favorite
License:
Bio: Privateer
More by TVMiller:Arduino Splash Resistant Toilet Foamer Arduino Motion Mute 1992 Isuzu Trooper Windshield Wiper Single Button Hack
Add instructable to:
