3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Arduino GPS Datalogger
Do you want to log some GPS data onto an SD card using your Arduino? Do you already own a Sparkfun microSD shield and GPS module? Did you try the Adafruit Sheild (although it is awesome and cheap) but it stole all of your pins? Want it to output into a nice, Google Earth friendly format? Well read on...
Step 1The Hardware
The Hardware
You will need:
1. An Arduino (which ever you prefer. I stick to the uno, duemilanove, mega, and this bad boy )
2. A GPS module (I'm using the EM-406 from Sparkfun )
3. A matching way to hook the GPS module to the Arduino (I went with Sparkfun's GPS Shield )
4. And a microSD Sheild (Again from Sparkfun )
Some optional stuff:
5. Indicator LED (ok ok I won't force Sparkfun on you for this guy)
6. A nice hard weatherproof case (I used the Pelican 1010 which fit perfectly)
7. Battery (No point logging GPS data tethered to your computer)
17 comments
Dec 10, 2011. 7:39 AMmrdakota says:
Great job on the Instructable!
For a first time, it was well constructed.
Now for my problem,
I'm not getting the log file header unless I have the Arduino connected to my computer USB and it is not logging any gps data.
The only thing I have different is the SD card shield, I'm using the Arduino wireless SD shield. http://arduino.cc/en/Main/ArduinoWirelessShield
At first I tried editing the SdFatConfig.h file to change the CS pin from 10 to 4 for my SD shield and that didn't work.
So I changed it back to pin 10 and modified the shield, ( cut the copper trace from pin 4 and connected it to the unused pin 10) still no luck.....
I really looking forward to getting this to work.
Dec 10, 2011. 8:23 AMmrdakota says:
Well by mistake , I installed a different micro SD card and it works PNY instead of SanDisk.
But still it doesn't work off the power plug only off the USB. I'm puzzled!
Dec 10, 2011. 8:26 AMmrdakota says:
My-BAD- again! It turns out my battery(5v) wasn't enough.
Everything is fine now with a 7.4v Li-Po
Hope this helps someone else in the future!
Mar 31, 2012. 10:35 PMRustie0125 says:
HI Jonny any News on the Accuracy problem in the code? , im buring to get this working
Apr 9, 2012. 5:54 AMRustie0125 says:
HI Jonny any news ?
Mar 26, 2012. 9:51 AMRustie0125 says:
Hi Thank you for sharing your hard work .! i have all the components but non is on the shields they all stand alone breakout boards. when i try and compile your code it gives me Alot of errors can you help ? mainly ones of missing Files or libraries can you please maybe add the links to all libraries needed
thanx
Mar 28, 2012. 9:09 PMRustie0125 says:
Hi Johnny
I got it to work thank you , I wantted to ask if you were aware that your GPS readings is very inaccurate . Iv done some research and it seems where the problem is is where you convert the output to int. instead of keeping them as is and saving them like that . I have media tek gps and the best accuracy I get when using your code is +- 10km range but when using a GPS example from Arduino I get 3 foot accuracy .
Is there a way you code step away from converting the output to int? And just print them as floats . ? Iv tried but I can get it working then
Thanx for the post very helpfull
Mar 28, 2012. 10:19 PMRustie0125 says:
Hi Jonny
Looking forward to your fix , I'm buzy with same setup . Please let me know if you got it fixed .
Mar 26, 2012. 9:59 AMRustie0125 says:
Also something else that I cant get from looking at the code is where or what pins is the Sd card attached to?
Nov 7, 2011. 7:14 PMmanashraja says:
Sir, excuse me. The link you have provided is making me download "FADFMAUGTW2B6VB.tmp". I am not getting the required "GPSDataLoggerInstructable.pde" file.
Oct 19, 2011. 8:45 AMmikeasaurus says:
great project!
Oct 18, 2011. 7:51 AMechovoice says:
nice tutorial, thanks for the code... works perfectly!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:jonnyboy323
