Introduction: Arduino Graphical Serial Communication With FlowStone (Blink LED)
Picture of Arduino Graphical Serial Communication With FlowStone (Blink LED)
Arduino is using widely for different kind of computer/electronic projects for many purposes, it has a well designed compiler that reduce coding and uploading time, FlowStone is a Graphical Programming Language studio that use hight graphical components with ability to internal coding with Ruby and Assembly for extending abilities and it has possibility to work with other programming languages like C/C++, C#, etc, this awesome abilities make FlowStone very powerful and flexible with easy learn and nice appearance that do many things in program creation engineering. It has been designed to work with different hardware to control and monitoring boards and sensors. It is very easy to install and very light weight for use in old and new windows based systems. Educational license will be useful for students and teachers to reduce cost of projects.
In this tutorial step by step with visual learning method I will show you how to make a project to turn on a LED in Arduino from FlowStone with graphical environment very easy and very interesting.
Step 1: Project Video
Step 2: Download FlowStone Www.dsprobotics.com/download
Picture of Download FlowStone  Www.dsprobotics.com/download
Step 3: Install FlowStone
Picture of Install FlowStone
Step 4: From File Menu Create New
Picture of From File Menu Create New
Step 5: Add COM Port Component From Toolbox to Base With Drag & Drop
Picture of Add COM Port Component From Toolbox to Base With Drag & Drop
Step 6: Add 3 Int Component
Picture of Add 3 Int Component
Step 7: Fill Them With This Values
Picture of Fill Them With This Values
Step 8: Tip 1: This Values Are Connection Parameters of Arduino Uno (Other Boards Could Be Different)
Picture of Tip 1: This Values Are Connection Parameters of Arduino Uno (Other Boards Could Be Different)
Step 9: Link Int Components to COM Port Component With Drag & Drop
Picture of Link Int Components to COM Port Component With  Drag & Drop
Step 10: Add 2 Boolean Component
Picture of Add 2 Boolean Component
Step 11: Link Them to COM Port
Picture of Link Them to COM Port
Step 12: Add 2 Int Component
Picture of Add 2 Int Component
Step 13: Link Them to COM Port
Step 14: Add 1 Boolean Component
Picture of Add 1 Boolean Component
Step 15: Link It to COM Port
Picture of Link It to COM Port
Step 16: Add a Trigger Component
Picture of Add a Trigger Component
Step 17: Link It to COM Port (1 > 3)
Picture of Link It to COM Port  (1 > 3)
Step 18: Add 1 LED Component, Right Click on It and Rename It to “Port State”
Picture of Add 1 LED Component, Right Click on It and Rename It to “Port State”
Step 19: Link COM Port to LED
Picture of Link COM Port to LED
Step 20: Add 1 Text Component
Picture of Add 1 Text Component
Step 21: Link COM Port to Text and Resize Text
Picture of Link COM Port to Text and Resize Text
Step 22: Open Connection With Click on “Open” Boolean and Check Logs on Text Component (LED On)
Picture of Open Connection With Click on “Open” Boolean and Check Logs on Text Component (LED On)
Step 23: Close Connection With Click on “Close” Boolean and Check Logs on Text Component (LED Off)
Picture of Close Connection With Click on “Close” Boolean and Check Logs on Text Component (LED Off)
Step 24: Clear Logs and Refresh Connection by Click on Trigger
Picture of Clear Logs and Refresh Connection by Click on Trigger
Step 25: Select All Component With Keyboard Shortcut “Ctrl+A”
Picture of Select All Component With Keyboard Shortcut “Ctrl+A”
Step 26: Right Click on a Component and Select “Make Module” Form Opened Menu
Picture of Right Click on a Component and Select “Make Module” Form Opened Menu
Step 27: Module Created and All Components Are Inside Module
Picture of Module  Created and All Components Are Inside Module
Step 28: Add 1 Button From Toolbox to Parent Base
Picture of Add 1 Button From Toolbox to Parent Base
Step 29: Resize Button With Right-down Corner Section and Rename It by Click on Small “P” in the Right-down Corner
Picture of Resize Button With Right-down Corner Section and Rename It by Click on Small “P” in the Right-down Corner
Step 30: Click on Module to Select It and Click on Small Tree-angle
Picture of Click on Module to Select It and Click on Small Tree-angle
Step 31: Module Will Be Opened in New Window
Picture of Module Will Be Opened in New Window
Step 32: Add 1 Input Component
Picture of Add 1 Input Component
Step 33: Link Input Component to COM Port Component
Picture of Link Input Component to COM Port Component
Step 34: Switch to Parent Window, Now You Can Link Button to Your Module
Picture of Switch to Parent Window, Now You Can Link Button to Your Module
Step 35: Link Button to Your Module
Picture of Link Button to Your Module
Step 36: Go to Your Module, Close Connection and Click on Trigger
Picture of Go to Your Module, Close Connection and Click on Trigger
Step 37: Put a LED to Arduino Like Schematic Blow and Attach Arduino USB to Computer
Picture of Put a LED to Arduino Like Schematic Blow and Attach Arduino USB to Computer
Step 38: Open Arduino IDE and Write This Code
Picture of Open Arduino IDE and Write This Code
Step 39: Upload Sketch to Arduino
Picture of Upload Sketch to Arduino
Step 40: Go Back to FlowStone Open Module and Open Connection
Picture of Go Back to FlowStone Open Module and Open Connection
Step 41: Click on Button Then LED Will Be Turned on for 3 Seconds.
Picture of Click on Button Then LED Will Be Turned on for 3 Seconds.
Step 42: Finished
Picture of Finished
Step 43: Project Source Files
armandosalinasperez (author)2017-02-05
Thank you!, This was very useful, i have problems trying to send more than one byte in order to control differents variables.
seamster (author)2016-02-01
This looks very useful. Thanks for sharing the details!
About This Instructable
1,624views
5favorites
License:
More by Eng_AliKazemi:Arduino Graphical Serial Communication with FlowStone (Blink LED)
Add instructable to:
